how to update or fix superuser after installing a rom or theme.
This is a discussion on how to update or fix superuser after installing a rom or theme. within the Droid X Help forums, part of the Droid X Discussion category; this is how to fix. go download superuser 2.3 apk after that open up the folder you had your old root files in (android sdk/tools ...
Results 1 to 2 of 2
Thread: how to update or fix superuser after installing a rom or theme.
    3 months registered100 Experience PointsTagger Second Class31 days registered7 days registered
    TheMr_Teddy's Avatar
    6750
    11
    Thumbs up how to update or fix superuser after installing a rom or theme.
    after that open up the folder you had your old root files in (android sdk/tools is where i had mine) and replace it with the new superuser 2.3 apk.
    now open cmd and type following command.
    adb push Superuser.apk /sdcard/Superuser.apk
    you might want to make sure the old superuser apk isnt on the sd card
    after the push run.....
    adb shell
    then type su for root access
    then you need to mount....... type this in mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
    then u need to remove the old superuser.apk by typing the following
    rm -r /system/app/Superuser.apk make sure the s in superuser is capitalized.
    now you can push the files to system.
    type following in cmd.
    cp /sdcard/Superuser.apk /system/app/Superuser.apk
    now to unmount mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
    now you can exit adb shell by typing exit in the cmd hope i helped. this is my first thread i just did this on my phone so happy fixing. then restart phone
    6750
    11
    Download starting... - Softpedia
    this is the site you need to go to download the new superuser. open the zip then open system and then app. it will be in there ok
  1. Help with removing Superuser Permission app?!?!
    By Bradfan04 in forum Droid X Hacks
    Last Post: 10-13-2010, 10:27 AM
  2. superuser help
    By Cupidsrage in forum Hacking Help
    Last Post: 09-26-2010, 09:27 PM
  3. Question about different Superuser.apk's
    By aholeinthewor1d in forum Droid X General Discussion
    Last Post: 09-18-2010, 11:47 AM
  4. Replies: 0
    Last Post: 09-16-2010, 12:03 AM
  5. how do i update superuser?
    By shottguy088 in forum Droid X Hacks
    Last Post: 09-01-2010, 02:12 AM
fix superuser
fix superuser permission
how to fix superuser
how to push superuser
how to update superuser
super user fix
superuser fix
superuser fixer
superuser update fixer
superuser update fixer apk
