How to transfer stuff from your computer to Phone?
This is a discussion on How to transfer stuff from your computer to Phone? within the Droid X Help forums, part of the Droid X Discussion category; I was wondering if theres an easier way to transfer stuff from your computer to phone? I have my USP plugged it and I tryed ...
Results 1 to 10 of 12
Thread: How to transfer stuff from your computer to Phone?
    Points: 2,437, Level: 29
    Level completed: 92%, Points required for next Level: 13
    Overall activity: 1.4%
    DolphinxManiax23's Avatar
    7637
    Cleveland, Ohio
    166
    I have my USP plugged it and I tryed to transfer some Icons over to my phone and it says somethin about its an PNG file and wont show then I unplug my phone and Id go to my gallery to check to see if it's there and my Icons are no where on my SD card? Sometimes it would take a while for certain stuff to show up on my SD card from transfering stuff from computer to phone.
    Does anyone know why I cant transfer PNG files? Or is there an easier way? I want these Icons on there and cant get them on.
    If anyone can help me out.
    Thanks soo much!
    Points: 146,349, Level: 100
    Overall activity: 71.4%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    If you have the X set to USB mass storage when you plug it in you should be able to just drag and drop the icons to whatever folder you want on your SD card. PNG files are supported. I do it all the time.
    Points: 1,052, Level: 17
    kk4df's Avatar
    8028
    47
    Try the Dropbox app
    validoption's Avatar
    1423
    232
    17 times
    Quote Originally Posted by kk4df View Post
    Try the Dropbox app
    +1 for Dropbox. Tonido is also pretty good, but where Dropbox requires the files in question to be in the Dropbox folder, Tonido requires the PC to be on. Tonido is great because you can access any file on the PC, regardless of folder, but there are some aspects I feel lack in comparison to dropbox--like being able to download .zip files.
    7637
    Cleveland, Ohio
    166
    I have installed dropbox...Now how do I get my icons from my computer from on dropbox to install on my phone?
    7637
    Cleveland, Ohio
    166
    Quote Originally Posted by Garemlin View Post
    How do I set it to usb mass storage when I plug it in?
    And I have the droid x!
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,816
    139 times
    Quote Originally Posted by DolphinxManiax23 View Post
    Drag the files into the public folder on your dropbox, they will show up in the public folder on your devices dropbox
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    After you plug it in pull down your notification bar and then click USB connection then USB Mass Storage.
    7637
    Cleveland, Ohio
    166
    Where's the notification bar at? All I see by the clock settings is MotoConnect.
    What I do to drag my Icons and stuff in my phone is By going to my computer then clicking on my phone and click on remove storge and I drag in my files that way. Some files work and stays in there but some dont.
    But I dont see notification bar though.
    Points: 1,195, Level: 18
    Level completed: 95%, Points required for next Level: 5
    brumby05's Avatar
    3633
    21
    ^the notification bar is on the phone.
  1. Replies: 7
    Last Post: 09-02-2010, 03:07 AM
  2. DROID X - Transfer files to/from my computer
    Last Post: 08-27-2010, 12:38 PM
  3. videos saved on my phone wont transfer
    By white ghost in forum Droid X Help
    Last Post: 08-25-2010, 07:46 PM
  4. Does insurance transfer with a phone if its put on a different line?
    By Djnardu in forum Droid X General Discussion
    Last Post: 07-28-2010, 04:51 PM
  5. How do I get my pic's from my phone to my computer
    By ckulmer in forum Droid X Help
    Last Post: 07-23-2010, 05:22 PM
how to download stuff from computer to phone
how to download stuff from your computer to your phone
how to download things from computer to phone
how to download things from your computer to your phone
how to move stuff from computer to phone
how to send things from computer to phone
how to transfer stuff from computer to phone
how to transfer things from computer to phone
transfer files from droid x to pc
transfering pictures from computer to droid x
