Returning X Cant adjust backlight
This is a discussion on Returning X Cant adjust backlight within the Droid X Help forums, part of the Droid X Discussion category; wondering if anyone else is having this issue. battery drains quickly brightness is turned all the way up (not on auto) i can lower it ...
Results 1 to 6 of 6
Thread: Returning X Cant adjust backlight
    george1974's Avatar
    936
    wondering if anyone else is having this issue. battery drains quickly brightness is turned all the way up (not on auto) i can lower it on the slider but it wont actually dim the screen. i took it to verizon and a tech checked it and said they would send me out a new one....after the 27th
    mcsinfl's Avatar
    19
    59
    have you tried the power control widget? long press somewhere on an empty space that is at least 4x1, choose widgets> power control. the far right button toggles high, low, and auto
    george1974's Avatar
    936
    yep along with a couple other widgets and no matter what screen stays at 100% brightness even though the slider is at 0
    Your first Group250 Experience PointsRecommendation Second ClassThree Friends100 Experience Points
    titans's Avatar
    52
    Why do you want to know?
    240
    13 times
    Try a factory reset.
    george1974's Avatar
    936
    did that. verizon tech messed with it for a good 2 hours said he had no clue why it wont dim. in fact the whole store was looking at it they said it was the first x they had come back. they have a new one on order for me.
    Having the exact same problem here. Brightness is at max even though slider is at 0. Have two X's to compare -- one is fine, the other clearly broken.
    Assuming we will have to exchange phones, what's the best way to preserve all settings, apps, etc.? In other words, is there a way to image my phone?
Droid x backlight stays on
adjust backlight droid x
ajust back light to turn off sooner on atrix
backlight droid x
can't adjust droid x brightness
droid X backlight broken
droid x adjust backlight
droid x back light
droid x backlight
droid x backlight all the way up
droid x backlight problems
droid x no backlight
how to turn up backlight on droid x
turn on backlight on droid x
xbacklight -get return 0
