Wont make/receive calls/texts/ internet. Wont activate after reset
This is a discussion on Wont make/receive calls/texts/ internet. Wont activate after reset within the Droid X Help forums, part of the Droid X Discussion category; I was using my phone all day just fine and around 8:30 tonight i tried sending a text and it wouldnt work, tried resending it, ...
Thread: Wont make/receive calls/texts/ internet. Wont activate after reset
    fighterpilot53's Avatar
    12775
    5
    I was using my phone all day just fine and around 8:30 tonight i tried sending a text and it wouldnt work, tried resending it, wouldnt work, tried making a phone call wouldnt work, tried going online wouldnt work. Its been 2 hours and still nothing, took out the battery a few times, SD card. I finnally hard reset it to factory settings.
    Now the problem is i cant call to activate it because it will not make phone calls. It says i have service.
    Im super frustrated because i need to call someone and this is the only phone i have. It worked fine before 2.2 came out which by the way i dont think did any benefit.
    please help!
    I have the same problem. If you happened to fix your issue, please let me know how it got resolved.
    Thanks
    Points: 2,950, Level: 33
    Level completed: 34%, Points required for next Level: 100
    Tagger Second Class250 Experience PointsCreated Album pictures100 Experience Points7 days registered
    X-tac23's Avatar
    501
    Port arthur, TX
    690
    27 times
    You tried *228 opt. 1. If you have service you should be able to make calls 3g doesn't effect that. Go in to your settings data manager then select data delivery. From there you will see the background data, roaming, data enabled. You want to make sure re last one is checked.
    IF YOU NEED HELP BE SPECIFIC , DON'T LEAVE ANYTHING OUT AND MOST IMPORTANT DON'T PANIC!!
    THERE'S NO I IN TEAM!!
    X Pursuant Achievements:
    z06mike's Avatar
    1491
    558
    23 times
    If not, you can also activate the phone online through your verizon account, or call them from a landline 1-800-922-0204.
  1. droid x wont txt
    By tu2kill in forum Droid X Help
    Last Post: 03-25-2011, 05:12 PM
  2. Droid wont receive, or make calls or texts, or internet
    By fighterpilot53 in forum Droid X Rescue Squad
    Last Post: 10-21-2010, 02:51 PM
  3. Droid X won't make calls or texts...help??
    By zthr33 in forum Droid X Help
    Last Post: 09-12-2010, 12:32 PM
  4. wont let me add another gmail account
    By 6thgear in forum Droid X Help
    Last Post: 08-27-2010, 02:36 AM
  5. nfl app wont stream anymore
    By newinfl80 in forum Droid X Apps
    Last Post: 08-23-2010, 03:24 AM
my android phone wont let me call or text
my android wont let me call or text
my phone wont let me call or text
my phone wont let me text or call
new phone won't make calls text internet
why wont my andriod let me make phn calls
why wont my droid text or call
why wont my phone let me call or text
why wont my phone let me text or call
