After 2.2 Upgrade, PDA Net will not connect
This is a discussion on After 2.2 Upgrade, PDA Net will not connect within the Droid X Help forums, part of the Droid X Discussion category; After yesterdays update, I tried using PDA net, for which I have the paid version (and phone is not rooted). When I go to connect ...
  • 1 Post By DebianDog
Thread: After 2.2 Upgrade, PDA Net will not connect
    Points: 2,349, Level: 29
    Level completed: 33%, Points required for next Level: 101
    250 Experience Points100 Experience PointsTagger Second Class31 days registered7 days registered
    bauerat02's Avatar
    10997
    Madison, WI
    50
    After yesterdays update, I tried using PDA net, for which I have the paid version (and phone is not rooted). When I go to connect it, it says make sure phone is connected and set to USB Debugging. It is set to that, and worked just fine before the update, but now nothing. Any ideas? Thanks!
    Rescue Squad
    Points: 42,712, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    Reload the client on your PC should fix it.
    On my Mac I know have to restart the OS to get it to reconnect without error Sent e-mail to dev.
    pudders's Avatar
    11207
    5
    Maybe needs to be patched. Use the feedback system or email the dev to see if they can help. I have had a few apps that needed an update before they would work again after 2.2 even something as simple as the led light app had to be updated.
    bauerat02's Avatar
    10997
    Madison, WI
    50
    Works after reinstalling to the laptop!
  1. Connect to car tv via Composite
    By EHDroid in forum Droid X Audio / Video
    Last Post: 03-02-2011, 11:17 PM
  2. USB connect ot PC from DX
    By stevewitt in forum Droid X Help
    Last Post: 08-27-2010, 05:14 PM
  3. Howdaya connect X to TV
    By captainwillie in forum Droid X Audio / Video
    Last Post: 08-16-2010, 07:45 PM
  4. Do I need Broadband connect to...
    By tourrider in forum Droid X General Discussion
    Last Post: 08-06-2010, 11:50 AM
  5. When i connect via USB to X, it crashes the PC
    By plumcrazy in forum Droid X Help
    Last Post: 07-15-2010, 10:52 PM
pda net upgrade
pda will not connect
pdanet does not connect to phone
pdanet facebook not loading
pdanet outpipe
pdanet will not connect
pdanet wont connect
pdanet wont connect to internet
pdanet wont connect to phone
pdanet wont load facebook
