I searched this, but couldn't find an answer.
So I see the walpapers you can add, some people are sharing on here. So how do you get them on the device?
I long press on the home screen and touch add wallpaper, but all I get are the stock ones? I have saved some options to a folder on the device (which I can see they are there when hooked to the PC) but when I try to get there on the device...no luck.
Anyone help with this? Thanks. (not quite two weeks in on this thing)
