Alarm in Sleep Mode
This is a discussion on Alarm in Sleep Mode within the Droid X Help forums, part of the Droid X Discussion category; Is it possible to set an alarm to go off when the X is in Sleep Mode? Or can alarms only go off when the ...
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By 10forty2
  • 1 Post By Phildo
Thread: Alarm in Sleep Mode
    Points: 1,926, Level: 26
    Level completed: 26%, Points required for next Level: 74
    seanmu13's Avatar
    11939
    5
    Alarm in Sleep Mode
    Is it possible to set an alarm to go off when the X is in Sleep Mode? Or can alarms only go off when the phone is on (awake)?
    Points: 1,844, Level: 25
    Level completed: 44%, Points required for next Level: 56
    10forty2's Avatar
    8649
    95
    11 times
    Unless the phone is turned off, I'm pretty sure the alarm will work regardless of the state....just like a phone call.
    seanmu13 likes this.
    For Beautiful Fine Art Photography Please Visit:
    http://dougloganphotography.zenfolio.com
    tracey's Avatar
    3841
    145
    What do you mean by sleep mode?
    seanmu13's Avatar
    11939
    5
    Whenever you press the power button the phone goes into 'sleep mode.' I don't own a DroidX yet so my terminology may be a little off.
    Points: 3,763, Level: 38
    Level completed: 76%, Points required for next Level: 37
    Overall activity: 3.7%
    31 days registered250 Experience Points100 Experience PointsTagger Second Class7 days registered
    Phildo's Avatar
    7190
    641
    31 times
    i only have silent, airplane, and power off
    look up alarm clock plus, i just started to use it, and it looks pretty promising
    seanmu13's Avatar
    11939
    5
    Quote Originally Posted by Phildo View Post
    Again, since I don't have the phone I'm probably using the wrong words, but whenever you just press the power button (not long press). I'm calling that state 'sleep mode'.
    Phildo's Avatar
    7190
    641
    31 times
    that is just turning the display off and locking the screen. in that case, even the stock alarm should work, but again check this out Alarm Clock PlusV1
    Points: 1,932, Level: 26
    Level completed: 32%, Points required for next Level: 68
    UnlikelySalsero's Avatar
    3437
    241
    32 times
    Quote Originally Posted by seanmu13 View Post
    The stock alarm works fine when the phone is in sleep mode. The phone turns off the screen if you have no activity for a set amount of time OR if you manually short press the power button.
    As someone else mentioned, it's just like a phone call will wake up the phone (display turns on, phone rings and/or vibrates), the alarm does the same thing.
    While you should check out alternate apps, the stock alarm that is in 2.2 works fine for me. (I don't remember if I used it in 2.1, I think it's the same).
    It has a "get louder" option that starts the sound reasonably quiet, then turns up the volume the longer you ignore it. With a good ringtone (high energy music), it works really well. I have mine set to vibrate also, and the combination would be extremely difficult to ignore.
    Don Baarns
  1. Is there an app to make me sleep?
    By eric eakin in forum Droid X Apps
    Last Post: 09-30-2010, 03:23 PM
  2. Better alarm app?
    By Neoele in forum Droid X Apps
    Last Post: 08-12-2010, 02:01 PM
  3. Alarm app
    By spsuamin in forum Droid X Apps
    Last Post: 08-05-2010, 10:20 PM
  4. alarm not working.
    By hartsgt in forum Droid X Help
    Last Post: 07-20-2010, 06:17 AM
  5. Alarm Snooze
    By mp7123 in forum Droid X Help
    Last Post: 07-19-2010, 08:15 AM
android alarm in sleep mode
android alarm sleep mode
android sleep mode alarm
android sleep mode alarm clock
online alarm clock that works in sleep mode
sleep mode android
sleep mode android alarm
will alarm work in sleep mode
