App that disables magnet sensor
This is a discussion on App that disables magnet sensor within the Droid X Help forums, part of the Droid X Discussion category; Just keep in mind it isn't just the placement of the magnet, it is also the strength of it. A very weak magnet may not ...
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Like Tree3Likes
Thread: App that disables magnet sensor
    Points: 123,642, Level: 100
    Overall activity: 92.9%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    Just keep in mind it isn't just the placement of the magnet, it is also the strength of it. A very weak magnet may not activate it unless it is right up against the magnet in the X. But an extremely strong magnet needs less range to activate. Best thing to do is to try out some different cases and just look inside around the edges to see if the car dock mode is activated.
    Merlin21's Avatar
    9429
    Roger that.... Will do
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    No issues with timeouts here but I also use Screebl to keep my screen active...the two apps seem to play well together.
    I do agree with you on screen facing towards magnets will eliminate it forcing the dock mode.
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    The Verizon case does not cause any problems.
    I don't agree with you ,in some way Neodymium Magnets
  1. Camera Sensor Issue
    By b0bj0e in forum Droid X General Discussion
    Last Post: 04-10-2012, 08:07 PM
  2. IR sensor on Droid X?
    By RED318is in forum Droid X General Discussion
    Last Post: 04-27-2011, 09:23 PM
  3. Played with a DX and a magnet
    Last Post: 08-23-2010, 12:59 PM
  4. G4 app using the sensor all the time?
    By impostor71 in forum Droid X Apps
    Last Post: 08-18-2010, 09:46 AM
  5. Proximity sensor issues
    By Droid FTW in forum Droid X Help
    Last Post: 07-22-2010, 02:28 AM
Droid X disable magnet sensor
android disable magnetic sensor
android magnet sensor disable app
disable magnetic sensor android
disable s view sensor
droid 2 disable magnet
droid x magnet
how to disable magnetic sensor
magnet off switch in android
