changing folder names
This is a discussion on changing folder names within the Droid X Help forums, part of the Droid X Discussion category; how do i change the contents of files in my gallery? not things on my sd card.. i'm a bit confused... i use AndroZip.. i ...
  • 1 Post By ToeJamm57
Thread: changing folder names
    Points: 4,567, Level: 43
    Level completed: 9%, Points required for next Level: 183
    jbreezy's Avatar
    8371
    Rock Hill, SC
    250
    how do i change the contents of files in my gallery? not things on my sd card.. i'm a bit confused... i use AndroZip.. i had trouble usin Astro.. but i'm tryin to figure out how to change the folder names in my gallery on my phone memory... hope i'm makin sense... where would this be located in the directory? thanks
    Rescue Squad
    Points: 32,688, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    Pictures will always write to /dcim/camera but you can make as many folders named anything you want.
    Swyped on my X
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    I use Astro for my file/folder management (not sure how it works with AndroZip). When in Astro I go to my picture folder (vmm_pics) where my folders are located. If I want to change the name of a folder I press and hold the folder. A menu appears giving me several options for the folder. Selecting "Edit" will take you to another menu with options (copy, delete, move, rename). Select "Rename" and you are good to go. Hope this helps.
    jbreezy likes this.
  1. Display Contact names
    By milo1s in forum Droid X Help
    Last Post: 01-17-2011, 09:51 PM
  2. e-mail icon names
    By ckracing in forum Droid X Help
    Last Post: 08-11-2010, 02:19 PM
  3. Voice not pronouncing names right
    By Mr. Chumley in forum Droid X Help
    Last Post: 08-10-2010, 03:40 PM
  4. Replies: 1
    Last Post: 07-19-2010, 04:39 PM
change folder names gallery
edit names on gallery folders
hod do i change the folder names on htc sense?
how to change gallery folder name android
how to change gallery folder name on android
how to change gallery folder name on droid
how to change name of folder on gallery
how to change the folder name on facebook
naming gallery folders in android
on android how do i change a gallery folder name
