Battery Issue.
This is a discussion on Battery Issue. within the Droid X Help forums, part of the Droid X Discussion category; Originally Posted by eXile If you have ATK set to auto-kill then it could be the culprit, but if you were having issues before hand ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
Thread: Battery Issue.
    Points: 2,437, Level: 29
    Level completed: 92%, Points required for next Level: 13
    Overall activity: 1.4%
    DolphinxManiax23's Avatar
    7637
    Cleveland, Ohio
    166
    Quote Originally Posted by eXile View Post
    If you have ATK set to auto-kill then it could be the culprit, but if you were having issues before hand it probably isn't the main issue. I would suggest a factory reset as your next option. Backup your data, apps and settings using MyBackupPro or Titanium if you have root. Then factory reset and see if it fixes the issue.
    It started draining battery after installed a Live wallpaper that was draining it pretty quick then I uninstalled it and thats when it was still draining it. Should I still try factory reset for that?
    7637
    Cleveland, Ohio
    166
    I just bought mybackup pro to backup settings and apps. After i do factory reset how do i install everything back after after i reset?
    Points: 1,995, Level: 26
    Level completed: 95%, Points required for next Level: 5
    31 days registered250 Experience PointsCreated Album pictures7 days registered100 Experience Points
    Bobby's Avatar
    5599
    170
    try this and please let me know your results
    How To: Double your DROID Xs battery* and more!
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    I've had my DX for about a month now and I think I have the battery management issue pretty much under control. I golfed 36 holes on Saturday and used the golf gps the entire time (about 9 hours) and still had 50% left when I went to dinner that night. The battery has definitely gotten better over time (after multiple full discharges and re-charges).
    Also, I've stopped using ATK and rely on JuiceDefender as my primary means of managing the battery. With JuiiceDefender I can go to bed with my phone at 100% and wake up to find it at 90%.
    Points: 7,208, Level: 56
    500 Experience Points250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    didiwags's Avatar
    55
    Minnesota
    1,450
    21 times
    I don't use juice defender and only get a 10% loss overnight also.
    Droid Does!!!
    Rescue Squad
    Points: 32,688, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,386
    331 times
    Quote Originally Posted by didiwags View Post
    Ditto
    Swyped on my X
  8. #17
    7637
    Cleveland, Ohio
    166
    Quote Originally Posted by ToeJamm57 View Post
    Thanks...I'll try that APP. Should I uninstall the ATK one when I install JuiceDefender? So is there any need in doing a Factory reset at all?
  9. #18
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    I still have ATK on my phone but I don't use it to kill apps any longer. To be honest I've tried so many things I'm not certain which made the biggest difference but I'm pretty sure having my screen brightness turned down played a big part. I also stopped using the living wallpapers.
    I use an app called Brightness Profiles that allows the user to set up multiple brightness settings and manage it with a single tap from the home screen. If you are in bright sunlight you can easily power up the screen to full and go back down just as easily.
  10. #19
    Rescue Squad
    DebianDog's Avatar
    6359
    4,386
    331 times
    Yep the screen is always your biggest battery waster
    Swyped on my X
  11. #20
    7637
    Cleveland, Ohio
    166
    How does JuiceDefender work? I have it installed. Like how do you kill things like the other app?
  1. Facebook and Battery issue
    By StacyKR92 in forum Droid X Help
    Last Post: 08-24-2010, 05:31 PM
  2. Extended Battery - Verizon has no idea what battery they're selling
    By shinjaejun in forum Droid X General Discussion
    Last Post: 08-19-2010, 10:29 PM
  3. Extended Battery and Beautiful Widget Issue?
    By jtdiddy in forum Droid X General Discussion
    Last Post: 08-18-2010, 07:11 PM
  4. My Droid X definitely has a battery or battery hog problem... Screenshots Inside
    By Talldarknfugly in forum Droid X General Discussion
    Last Post: 08-03-2010, 11:44 AM
  5. Anyone else having this Battery issue???
    By mzerhusen10 in forum Droid X Help
    Last Post: 07-19-2010, 11:59 PM
droid x aftermarket battery
droid x won't recognize my battery
facebook login page mobile
how do i get a 100% completion in let's golf 2#gsc.tab
