Wifi not working
This is a discussion on Wifi not working within the Droid X Help forums, part of the Droid X Discussion category; Has anyone had a problem with their wifi not working? It says I'm connected but when I go to browse the web the pages never ...
Results 1 to 6 of 6
Thread: Wifi not working
    31 days registered100 Experience Points7 days registered
    diggityd's Avatar
    6121
    18
    Wifi not working
    Has anyone had a problem with their wifi not working? It says I'm connected but when I go to browse the web the pages never load. I'm 100% sure the password on the wifi connection is correct and it even says I'm connected.
    Anyone had this issue??
    X Lurker Jeyrivera89's Avatar
    8267
    Somerville, Ma, USA
    14
    Actually yes, but it turned out to be a problem with my router settings. I had to manually set my wifi connection (menu-advanced) instead of auto ip.
    A loose tongue often gets into tight places...
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    I would delete the wifi connection from your phone and reconfigure it...
    Here are some links to other threads that might also help ya....
    http://www.droidxforums.com/forum/dr...tml?pagenumber
    Help, My DX wifi connection unstable.
    Points: 1,585, Level: 22
    Level completed: 85%, Points required for next Level: 15
    Overall activity: 2.2%
    250 Experience Points31 days registeredTagger Second Class100 Experience Points7 days registered
    EdgeKrusher187's Avatar
    6025
    Minneapolis, MN
    75
    Yes, and then I dropped the phone and WiFi started working (seriously).
    I have had some issues with my home router, narrowed it down to Wireless N, the specs on the phone say that it is capable of wireless N, but it didn't work. I would get connected, get an IP, but would not be able to use the internet. I changed the wireless to G only on my router and now I can connect and surf the internet with no problems. I don't know if this is an issue with the hardware or software but N just does not work for me.
    diggityd's Avatar
    6121
    18
    I'll check the hardware, never thought of it being a hardware issue on the router b/c my computer still works fine and my old blackberry and palm pre both worked just fine.
    I've connected to other wifi connections and they seem to work fine on my DX too. Weird.
    20,509
    885 times
    Quote Originally Posted by EdgeKrusher187 View Post
    How far of a drop are we talking?
  1. GPS not working
    By droidkat in forum Droid X Help
    Last Post: 10-22-2011, 03:08 PM
  2. Youtube not working
    By Phatkat66 in forum Droid X Help
    Last Post: 08-27-2010, 07:11 AM
  3. DirectTV working again
    By DebianDog in forum Droid X Apps
    Last Post: 08-26-2010, 06:07 PM
  4. GPS working?
    By Djnardu in forum Droid X General Discussion
    Last Post: 07-27-2010, 03:54 AM
  5. alarm not working.
    By hartsgt in forum Droid X Help
    Last Post: 07-20-2010, 06:17 AM
droid x connect to wifi but not working
droid x connected to wifi but not working
droid x connected wifi but not working
droid x shows connected to wifi but will not go online
droid x wifi connected but not working
droid x wifi not working
droid x wifi says connected but not working
wifi not working droid x
wifi not working on droid x
wifi on droid x not working
