Phone doesnt turn on
This is a discussion on Phone doesnt turn on within the Droid X Help forums, part of the Droid X Discussion category; i rooted my droid x and tried to put cyanogen mod on it but it failed so i thought oh well i try a different ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Phone doesnt turn on
    Points: 567, Level: 11
    Level completed: 34%, Points required for next Level: 33
    Overall activity: 27.0%
    blobbolb2's Avatar
    70612
    Jan 2015
    15
    i rooted my droid x and tried to put cyanogen mod on it but it failed so i thought oh well i try a different one but when i tried to reboot it stayed on the m and recently i tried to turn it on again but this time it didnt turn on at all so i thought the battery was dead so i plugged it in to a wall charger and it went to the m like usual but when i unplugged it it instantly turned off and a green led light flashed i tried to turn it on again but still nothing happened so i plugged it in longer and it did the same thing battery works fine ive tried it in another droid x but then i tried to plug it in without the battery and it did the same thing it did with the battery so i dont know if its a hardware problem or a software problem plz help
    Points: 18,680, Level: 86
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Charging often doesn't work if ROM doesn't work
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by blobbolb2 View Post
    You likely need a fastboot cable, or spare battery charger, some links in my list.
    sd_shadow's [Collection] of Links for: Droid X (MB810)
    blobbolb2's Avatar
    70612
    Jan 2015
    15
    i have tried plugging it in to my computer but it just flashes a green led and i have got to the recovery and tried to flash stock and custom roms NONE worked i think it is never gonna work again
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Stock ROM is not installed in recovery must use RSD lite or ezSBF
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    And if it says Android Recovery you can't install custom roms either
    Must use cwm recovery for all ROMs except kitkat/cm12 then you need twrp
    blobbolb2's Avatar
    70612
    Jan 2015
    15
    Also when i get to the bootloader it says low battery unable to program but the battery is fine
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    or it's not fine
    Sent from my XT907 using Tapatalk
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    fully charge battery with other Droid x
  1. Replies: 6
    Last Post: 11-16-2011, 08:23 AM
  2. Replies: 4
    Last Post: 05-16-2011, 11:54 AM
  3. Replies: 4
    Last Post: 11-23-2010, 12:24 AM
  4. Replies: 3
    Last Post: 11-01-2010, 06:08 PM
  5. my phone is DOESNT wipe!!!
    By sruel3216 in forum Droid X Hacks
    Last Post: 09-23-2010, 12:00 AM
