Blue triangle on the status bar... Verizon has no idea.....
This is a discussion on Blue triangle on the status bar... Verizon has no idea..... within the Droid X Help forums, part of the Droid X Discussion category; Ok so I had AT&T with an IPhone4, I then canceled my plan to port my number to tmobile. I tried tmobile out for 3 ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Blue triangle on the status bar... Verizon has no idea.....
    Tagger Second Class
    Acourtlandt's Avatar
    8265
    Tampa,FL
    7
    Ok so I had AT&T with an IPhone4, I then canceled my plan to port my number to tmobile. I tried tmobile out for 3 days and it sucked so I then ported that same number over to verizon and got the droid x. I activated my phone after getting it in the mail. It had a blue triangle in the status bar after activating, and when I looked in settings>about phone> satus> it said roaming and network unknown. Since then I've gone to the verizon store, they tried *228, battery pull, and finally replacing the phone. Well, The blue triangle is still there and I'm still supposedly "roaming"..... It's been a week since I've activated the phone. What do I do?
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,816
    139 times
    There is no charge for roaming on voice or data with VZW.
    Never seen a blue triangle tho...
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    X Lurker Jeyrivera89's Avatar
    8267
    Somerville, Ma, USA
    14
    Check your coverage area. You might have a weak VZW signal in your area. Or perhaps try going outside and activating the device. (like a gps)
    You never know.
    @backnblack
    Love your signature
    A loose tongue often gets into tight places...
    Points: 123,642, Level: 100
    Overall activity: 92.9%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    The blue triangle has something to do with no data connection available and you are not on a VZW plan. I get it on my DX when I unactivate it and swap back to my D1. Can you use the phone at all???? Maybe try reactivating it. Maybe something went wrong with your number port.
    Tagger Second Class
    8265
    Tampa,FL
    7
    I am in the middle of tampa,fl its a very good coverage area. I can use my voice and data fine from what I know. I think it has to do with my port too but no idea what to do about it!
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Have you called into VZW tech support to have them check your account and possibly reset it (I know in your OP you went into your local store)? You can call *611 from your phone or they may request that you call from a different number for troubleshooting purposes...
    20,509
    885 times
    And welcome to the forums!!
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    i suggest trying to reactivate it by calling VZW
    Tagger Second Class
    8265
    Tampa,FL
    7
    Thank you@ small towngirl. I've gone through vzw troubleshooting over the phone 2 times for about an hour each. They had me turn off my roaming banner and my data....battery pull *228. They said they would run tests and get me to another tech support guy..... im still waiting for the other tech support person to call, its been a few days.
    20,509
    885 times
    Quote Originally Posted by Acourtlandt View Post
    Possibly a factory reset and reactivate to ensure that everything has ported correctly for the carrier change...hope ya get soon tho I am sure that tech support person is on vacation right now...haha
  1. Blue triangle in status bar?
    By anomaly in forum Droid X General Discussion
    Last Post: 12-20-2011, 12:10 PM
  2. An IDEA OF EPIC PROPORTIONS!!!!
    By hollywood in forum Off-Topic Discussion
    Last Post: 09-01-2010, 03:05 PM
  3. Extended Battery - Verizon has no idea what battery they're selling
    By shinjaejun in forum Droid X General Discussion
    Last Post: 08-19-2010, 10:29 PM
  4. Flashing Blue Triangle; VZW doesn't know what it is.
    By holydroid in forum Droid X Help
    Last Post: 08-16-2010, 11:50 AM
  5. Idea for new emulator controls..
    By rafarquhar in forum Droid X General Discussion
    Last Post: 08-14-2010, 02:04 AM
Flashing blue triangle on droid
blinking blue triangle on droid
blue triangle on droid 2 global
blue triangle on droid x
blue triangle verizon
blue triangle verizon phone
droid 2 global blue triangle
flashing blue triangle verizon
verizon blue triangle
verizon wireless blue triangle
