Droid x2 erratic behavior
This is a discussion on Droid x2 erratic behavior within the Droid X Help forums, part of the Droid X Discussion category; I bought a droid x2 on ebay and it select what want and has very erratic behavior like has ghost or virus can any one ...
Results 1 to 2 of 2
Thread: Droid x2 erratic behavior
    I bought a droid x2 on ebay and it select what want and has very erratic behavior like has ghost or virus can any one tell what is wrong or should I send it back.
    Points: 18,680, Level: 86
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by artistjw View Post
    what does that mean? you installed a custom rom? rooted?...
    maybe could be a bad app, bad firmware, bad digitizer...
    depends on what you want to do with it, and if you are the one that broke it.
  1. Erratic Battery Reporting on 2.3.4
    By Viskey in forum Droid X2 Support
    Last Post: 11-21-2011, 09:29 AM
  2. Odd behavior lately
    By spartacus_33 in forum Droid X Help
    Last Post: 08-21-2011, 12:04 PM
  3. Erratic screen display and button functions
    By inceptor in forum Droid X Help
    Last Post: 06-21-2011, 08:55 PM
  4. Enigmatic Update...Really wierd Droid Behavior
    By SnoProLADD in forum Droid X Help
    Last Post: 12-28-2010, 03:29 PM
  5. Strange new Gmail behavior
    By iresq in forum Droid X Help
    Last Post: 09-27-2010, 06:16 PM
