Is my tilt sensor messed up?
This is a discussion on Is my tilt sensor messed up? within the Droid X Help forums, part of the Droid X Discussion category; I was trying to play a racing app called 'Steampunk Racing 3D' and for some reason my car would veer off the course as if ...
Results 1 to 1 of 1
Thread: Is my tilt sensor messed up?
    Points: 198, Level: 3
    Level completed: 96%, Points required for next Level: 2
    medbot's Avatar
    70296
    Dec 2014
    Unhappy Is my tilt sensor messed up?
    I was trying to play a racing app called 'Steampunk Racing 3D' and for some reason my car would veer off the course as if I had tilted my phone sharply to one side when it was level. I don't understand, is this a problem with the app or does the phone mistakenly think i'm tilting it? In addition, when I hold my finger on the screen to accelerate the car will decelerate even through my finger is still on the screen. Is this an app problem or is the problem with the phone itself?
  1. Proximity Sensor
    By tshelby73 in forum Droid X2 Support
    Last Post: 12-19-2011, 10:23 PM
  2. G Sensor Issue
    By bclown90 in forum Droid X2 Support
    Last Post: 08-18-2011, 02:17 AM
  3. Accelerometer only works when you tilt left?
    By crazedmonk in forum Droid X Help
    Last Post: 09-22-2010, 06:06 AM
  4. G4 app using the sensor all the time?
    By impostor71 in forum Droid X Apps
    Last Post: 08-18-2010, 10:46 AM
  5. Tilt feature not working for internet?
    By no0bama in forum Droid X Help
    Last Post: 07-24-2010, 03:13 PM
