Reformat/Reset my phone?
This is a discussion on Reformat/Reset my phone? within the Droid X Help forums, part of the Droid X Discussion category; Morning folks I think it's time to reformat my phone and start clean I guess it's called reset. I googled some process but think it ...
Results 1 to 10 of 15
Thread: Reformat/Reset my phone?
    Points: 2,194, Level: 28
    Level completed: 30%, Points required for next Level: 106
    drdave's Avatar
    66513
    Aug 2013
    32
    Morning folks I think it's time to reformat my phone and start clean I guess it's called reset. I googled some process but think it safe to check with the group for expert advise before I go diving into to something I might regret later on.
    I do have at least one app I would like to reinstall if possible I think it's "Easy Tether" And maybe others too it all depends.
    Following that I do want all my bookmarks available and possibly import just some of them instead of all the junk I saved.
    Need to back up my contacts and also just bring back in a few of them not all. I think gmail been backing them up automatically though need to double check.
    I am sure other things I want to resintall/import etc as long as i can manke them available in the event I have to go back and retrieve them later.
    Just too much junk on the phone right now so I would like to start over with a clean slate until I can afford to buy a newer model phone.
    I have a Motorola Droid X2
    Any help appreaciated folks
    Points: 18,680, Level: 86
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    root, if not already with Magic MD5 root
    For apps
    Install Titanium backup, and buy the pro upgrade and install it (you need them both to restore app data)
    Open Titanium Backup and press the "Options" hard-key. Then press "Batch." Run the Backup all User Apps tool and wait for the process to complete.
    For Browser
    Bookmark Backup Open "Backup Bookmarks" and backup your browser bookmarks.
    verify that contacts are backed up/ synced or backup to sd card
    Nandroid: A nandroid backup is a complete image of current system
    HowTo: Perform a bootstrap (or nandroid) backup and recovery of X2
    Install BSR and make a Nandroid backup
    drdave's Avatar
    66513
    Aug 2013
    32
    Thanks a lot for the info.
    Will post back if i encounter any issues.
    drdave's Avatar
    66513
    Aug 2013
    32
    I assume I root first?
    The Titanium won't work because I did not root yet. So root then backup data?
    Also I do not have SD Card only back ups on my phone internal storage.
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Quote Originally Posted by drdave View Post
    The droid x2 has a internal SD card
    That is all you need.
    What system version is installed?
    See settings/about phone
    drdave's Avatar
    66513
    Aug 2013
    32
    The one mentioned in the video 1.3.418
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    Yes, root first if you want app data backed up.
    drdave's Avatar
    66513
    Aug 2013
    32
    Problem I want to be able to go back later and get anything else I might not have thought of. That is, apart from what I already mentioned.
    Just can't think of what else I don't want to loose but basically if I can get back everything I need later that would be great. Not just that but also my app settings as well.
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    288 times
    The nandroid backs up everything...
    Titanium backup pro backs up app data which includes settings
    drdave's Avatar
    66513
    Aug 2013
    32
    I may have to go with the nandroid then.
    Thanks a lot for your help I really appreciate it.
  1. Easiest way to reset phone from 604?
    By CEV in forum Droid X RS Guides
    Last Post: 09-20-2013, 09:41 PM
  2. Phone Reset.. maybey?
    By ironhorse in forum Droid X Help
    Last Post: 08-29-2011, 04:44 PM
  3. How to reformat phone without volume buttons?
    By weenstan in forum Droid X Help
    Last Post: 06-05-2011, 02:00 AM
  4. Totally Reset my phone??
    By sharpie201 in forum Hacking Help
    Last Post: 05-18-2011, 10:26 AM
  5. SD Card corrupted, cannot reformat
    By joneee in forum Droid X Help
    Last Post: 10-03-2010, 03:09 PM
droid x
