Please help. Droid X stuck on M, I can get to the recovery screen !
This is a discussion on Please help. Droid X stuck on M, I can get to the recovery screen ! within the Droid X Help forums, part of the Droid X Discussion category; Can someone with more knownledge than I, please help. Droid X was rooted with ezroot. I never removed any bloatware. I did move the SU ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Please help. Droid X stuck on M, I can get to the recovery screen !
    rkelly's Avatar
    8131
    Post Please help. Droid X stuck on M, I can get to the recovery screen !
    Droid X was rooted with ezroot. I never removed any bloatware. I did move the SU file to the xbin folder as instructed in one of the post I read. I downloaded what I belived to be the 2.2 froyo update. Put the undate.zip on the root of my sdcard. Ran update through recovery mode. Rebooted phone after install was complete. Droid X is stuck on M screen and will not go any futher. I can get back to recovery screen with home+power button. Tried to run update again, but it says . error in sdcard update ( status 2 ) ! I have tried the format and clear chach, but no sucess. Any help would be great !
    Thank you
    Points: 1,650, Level: 23
    kdkinc's Avatar
    2843
    Inverness , FL
    40
    Cool
    Quote Originally Posted by rkelly View Post
    Thank you
    The title of this thread link is how to unbrick your phone....YOU DO NOT have a brick...
    READ the thread there is some GOOD stuff that will help. What you have IS a easy fix Don't sweat it .And you don't have to do a major reset of the phone using a file were not suppose to talk about .
    http://www.droidforums.net/forum/dro...r-droid-x.html
    rkelly likes this.
    rkelly's Avatar
    8131
    Thanks, Im going to give it a shot. Im a newbie as well, so I didn't mean to post in the wrong area if I did so.. Thanks again !!
    supahrob's Avatar
    96
    Riverside, CA
    211
    8 times
    I had something similar happen to me while I was updating to 2.2... if it's not too late, try this: Reboot your phone, when it sticks on the "M" logo, press the power button once. When I did that, it brought me to the recovery screen/menu. I am not sure what caused it, but from there I could select "reboot phone now" or whatever it was and then everything booted fine.
    Take care,
    Rob
    REAL men practice Biblical Hermeneutics!
    rkelly's Avatar
    8131
    Thank you KDKINC. The link you posted took me to a wealth on information. I followed the instructions there, and was able to fully restore my Droid X.. I guess I'll just waite until the offical 2.2 is released this time around.. Thanks again !! THREAD CLOSED
    kdkinc's Avatar
    2843
    Inverness , FL
    40
    Glad it worked...
    I had to use it myself last night to GO BACK to 2.1 due to a Motorola waring I saw posted . Stating "no OTA for people with current leaked 2.2."
    Points: 4,409, Level: 42
    Level completed: 30%, Points required for next Level: 141
    Carpetman's Avatar
    2459
    371
    I'm stuck on the M and I've tried pushing all buttons and still stuck on M . Please help!!!
    kdkinc's Avatar
    2843
    Inverness , FL
    40
    try post #2 again .
    Its all there BE patient use the correct tools You'll get it .
    Sometimes a battery pull then reboot WITH YOUR finger on the Home button WHILE inserting the battery can help then,,,, if needed push power button with finger on home button.
    Points: 1,675, Level: 23
    Level completed: 75%, Points required for next Level: 25
    250 Experience Points100 Experience Points31 days registeredTagger Second Class7 days registered
    StuntinX's Avatar
    8837
    47
    wtf
    Quote Originally Posted by kdkinc View Post
    try post #2 again .
    I got an "!" in side of a triangle and a droid guy... wtf
    StuntinX's Avatar
    8837
    47
    Can one send me the SBF link?! I can't seem to get it sent to me from the guy on the droid.net forum
  1. Droid X Stuck at Boot
    By James in forum Droid X Hacks
    Last Post: 09-22-2010, 12:14 PM
  2. Droid X Recovery - coming soon (by Koush)
    By Metalheadzaid in forum Droid X Hacks
    Last Post: 09-15-2010, 12:03 PM
  3. Droid X Bootstrap Recovery by Koush
    By JMuldrow in forum Droid X General Discussion
    Last Post: 08-21-2010, 03:17 PM
  4. Droid X recovery has arrived!
    By JohnDroid in forum Droid X News
    Last Post: 08-19-2010, 12:34 PM
droid 2 stuck at M
droid 2 stuck on m logo
droid x Stuck at M
droid x stuck at M logo
droid x stuck at m screen
droid x stuck on M
droid x stuck on M screen
droid x stuck on m logo
droid x stuck on motorola screen
stuck at m droid x
