my battery died now phone won't turn on!!!! HELP PLEASE
This is a discussion on my battery died now phone won't turn on!!!! HELP PLEASE within the Droid X Help forums, part of the Droid X Discussion category; i just purposely ran my extended vzw battery down all the way, plugged it up to my laptop with usb, now it won't turn back ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: my battery died now phone won't turn on!!!! HELP PLEASE
    Points: 2,046, Level: 27
    Level completed: 31%, Points required for next Level: 104
    KevenW's Avatar
    5911
    178
    i just purposely ran my extended vzw battery down all the way, plugged it up to my laptop with usb, now it won't turn back on!!! Can anybody help?
    KevenW's Avatar
    5911
    178
    it's also not showing the M on the screen when i plug it up but the green charging light is coming on at the top
    Points: 25,696, Level: 96
    Level completed: 35%, Points required for next Level: 654
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    turn off and put on the WALL CHARGER for an hour. DO NOT touch it til the hour is up.
    KevenW's Avatar
    5911
    178
    k i'll do that. i put the stock battery in it which is fully charged and it came on. I was wondering if maybe that dead batt didnt have enough juice to fire it up. will it be ok to keep the stock batt in for 20 min or so and do some stuff that I was about to do, then put the dead battery back in and use the wall charger and just let it charge till morning?
    1000 Experience Points500 Experience Points250 Experience Points100 Experience Points7 days registered
    shinjaejun's Avatar
    2584
    Pennsylvania
    278
    battery needs to hit a minimum of 20% or so to turn back on again.
    I think you'd be OK to swap batteries. remember the Li Ions dont have some of the issues of other rechargeables.
    I'm not angry, I'm from Philly
    Points: 6,551, Level: 53
    Level completed: 1%, Points required for next Level: 199
    B360155's Avatar
    217
    North Richland Hills, TX
    389
    32 times
    When you drain a battery completely, the DX will not power up immediately upon plugging it into either a usb or a wall outlet. After being plugged in for 10 or 15 minutes, it should develop sufficient power to power back on again at which time you can use it again.
    KevenW's Avatar
    5911
    178
    got it going. thanks
    X Pursuant Achievements:
    z06mike's Avatar
    1491
    558
    23 times
    The computer does not give it enough juice to get it going quickly. Only the wall charger will do that. You could probably get enough power after about 5 minutes on the wall charger whereas it would take you probably 20 to get enough out a comp.
    Points: 7,208, Level: 56
    500 Experience Points250 Experience PointsCreated Album picturesThree Friends100 Experience Points
    didiwags's Avatar
    55
    Minnesota
    1,450
    21 times
    Yeah I would not depend on your PC as a charger. It just does not put out enough juice to charge it efficently! Like the others say, when you kill the battery it needs to charge for awhile before you can turn it back on!
    Droid Does!!!
    movadoevo8's Avatar
    628
    591
    8 times
    Fyi if your battery dies and you are trying to charge it with usb cable connected to a laptop it ain't turn on. I had the same issue then connected it to the wall charger waited 5 mins and boonmm fired right up.
  1. How to turn off phone function (Use data on wifi only)
    By iubball in forum Droid X General Discussion
    Last Post: 09-13-2010, 03:38 PM
  2. Replies: 21
    Last Post: 08-29-2010, 01:07 PM
  3. Battery died overnight
    By NolBi-Wan in forum Droid X General Discussion
    Last Post: 08-23-2010, 11:20 AM
  4. Lost power yesterday for 8+ hrs and my X battery died....
    By dinatwin in forum Droid X General Discussion
    Last Post: 08-19-2010, 07:37 AM
  5. Battery died, took long time to come back on
    By aeyster84 in forum Droid X General Discussion
    Last Post: 08-14-2010, 04:11 AM
android ran out of battery, won't restart
droid battery died now wont turn
droid bionic battery died won't turn on
my android wont come back on battery dying
my lg motion died , wont come back on
my phone died and wont turn back on
razor x wont start up after dead battery
s3 battery went dead and now it wont turn on
the battery died on my laptop now the screen wont come on
when your droid phone dies adn wont turn on
