Help! BootLoop!
This is a discussion on Help! BootLoop! within the Droid X Help forums, part of the Droid X Discussion category; I was trying to install Droid X bootstrap and when I went to ROM manager to install it.... i get bootloop. can anyone help?...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
Thread: Help! BootLoop!
    tank72's Avatar
    8018
    13
    Help! BootLoop!
    Points: 25,696, Level: 96
    Level completed: 35%, Points required for next Level: 654
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    were you rooted? you have to install the bootstrap then clockwork. let me know if this fixes anything
    tank72's Avatar
    8018
    13
    Yes rooted, now i cant install anything cuz it keeps re-booting
    tank72's Avatar
    8018
    13
    Can I read my sd card if i put it in a computer?
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    Quote Originally Posted by tank72 View Post
    yes but what do you plan on doing? and when you say bootlooping can you describe it a bit more?
    tank72's Avatar
    8018
    13
    I just want the phone working again. I dont mind if its back to stock or rooted 2.2 i just need it to work. When I power it on the "M" shows then "DROID" then the red eye. then after about ten second back to "DROID' then red eye then repeats over and over..... Oh I thot that maybe I could replace update.zip with a new copy by putting the sd card in my computer
    tank72's Avatar
    8018
    13
    When I try RSD lite it says failed flashing process (0x7100) phone connected
    X Pursuant Achievements:
    z06mike's Avatar
    1491
    558
    23 times
    Go into recovery mode and do a factory reset. Reboot and see if that takes care of the problem.
    tank72's Avatar
    8018
    13
    Ive done that about 4 times
    z06mike's Avatar
    1491
    558
    23 times
    Did you try to flash the stock 2.1 back onto the phone?
  1. If your X is stuck in a bootloop you want to look here!!!
    By BringTherain403 in forum Droid X Hacks
    Last Post: 10-05-2011, 05:38 AM
  2. Clarifications on Bootloop, Brick, and Recovery Menu, and ROM
    By davidx in forum Droid X General Discussion
    Last Post: 08-21-2010, 12:45 PM
  3. Is my bootloop recoverable?
    By Xfactor1 in forum Droid X Help
    Last Post: 08-04-2010, 07:29 AM
