switching ROMs?
This is a discussion on switching ROMs? within the Droid X Help forums, part of the Droid X Discussion category; This is the message which pops up sometimes when using Google Play: Sorry! The process com.google.process.gapps has stopped unexpectedly. Please try again. Force close...
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Like Tree4Likes
Thread: switching ROMs?
    Points: 2,440, Level: 29
    Level completed: 94%, Points required for next Level: 10
    Overall activity: 5.4%
    fofopuka's Avatar
    63453
    Dec 2012
    68
    Points: 12,678, Level: 73
    Level completed: 57%, Points required for next Level: 172
    Overall activity: 18.0%
    csk415's Avatar
    29658
    North Texas
    1,812
    54 times
    Quote Originally Posted by fofopuka View Post
    Did the md5 match when you downloaded rom? If not redownload rom and get a matching md5. If it did match reflash the rom without doing wipes or just do full wipes and reinstall
    sd_shadow likes this.
    What rom do I run today??
    1kds SBF http://www.droidxforums.com/forum/dr...-problems.html
    If you are in a state of "OMG I jacked my phone up". Go here for help.http://www.droidxforums.com/forum/droid-x-rescue-squad/
    fofopuka's Avatar
    63453
    Dec 2012
    68
    Hi, yes the MD5 matched. I will have to make a nandroid and backup my launcher/shortcuts before I flash again, since I installed some new apps.
    csk415's Avatar
    29658
    North Texas
    1,812
    54 times
    Do your back ups just incase. If you just reflash the rom without wipes it shouldn't remove anything. If you do full wipes and reflash then everything will be gone. If the problem goes away after the reflash, redo your nandroid and delete the old ones. The old nandroid will still have the problem. Your launcher/shortcuts will still be good for future use.
    fofopuka's Avatar
    63453
    Dec 2012
    68
    Thanks for the advice. I have made a nandroid, and am also backing up my apps and data with MyBackup Root.
    Just a question, when I wiped, flashed VX-L and restored my apps, could restoring the apps have somehow have caused a problem with gapps?
    csk415's Avatar
    29658
    North Texas
    1,812
    54 times
    Hey fofopuka which vortex did you download? I was re-reading your first post and it seems you downloaded the wrong one. Did you download VXR, VXL or VXLR? If it was VXR or VXL, those versions had some issues. VXLR is the latest and the one you need to be on. There should be a active link in the last few posts of the thread I linked below. If you are on VXLR then do what i suggested above. If I remember vxl had some camera issues and was fixed in vxlr.
    http://rootzwiki.com/index.php?/topi...r-(01/24/2013)
  8. #17
    fofopuka's Avatar
    63453
    Dec 2012
    68
    I was looking and the only one I could find on the rootzwiki page was the VXL, I didn't know there is a VXLR
    I will have to take a look at that link and read it thoroughly through before trying to install. My SD card is getting full...
  9. #18
    csk415's Avatar
    29658
    North Texas
    1,812
    54 times
    Sorry i didnt catch this sooner. Until you get on vxlr you will have some bugs with the version your on. The aroma installer on vxlr is pretty sweet and makes flashing the rom fun. Read the devs first post in that thread and you should be good to go. You will like it so much better.
  10. #19
    fofopuka's Avatar
    63453
    Dec 2012
    68
    I have downloaded the VXLR installer and the MD5 checks out, I haven't flashed it yet. I am thinking of flashing VXLR on a different phone to try it out.
    Just a general question, if I put this SD card in different Droid X phone, boot to CWM and restore nandroid backup of say, for example RC-1, it should copy everything I had on this phone to the new one, correct?
  11. #20
    Points: 16,963, Level: 83
    Level completed: 23%, Points required for next Level: 387
    Overall activity: 99.8%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    4,125
    437 times
    It will copy what ever the nandroid contained, like apps, and passwords, contacts and so on.
    Sent from my Moto X
  1. Question on switching/updating roms
    By pyrozen in forum Droid X2 Hacks
    Last Post: 10-24-2011, 09:25 PM
  2. Help switching roms
    By zgruven in forum Droid X Help
    Last Post: 10-19-2011, 10:53 PM
  3. Switching roms from CM4DX
    By scitzo in forum Hacking Help
    Last Post: 07-12-2011, 07:00 AM
  4. Switching between ssx and froyo roms
    By 3rotorRX8 in forum Gingerbread Roms
    Last Post: 07-05-2011, 07:13 AM
  5. Switching ROMs
    By johnbergsing in forum Droid X ROMs
    Last Post: 02-10-2011, 12:34 PM
droid x vxl theme download green
vortex rc for droid x xda
