So from the home screen you have the slider bar on the left to unlock the phone and a slider bar on the right to "silence the phone". When I slide the right bar it turns off the ringer and the vibrate so if someone calls the only way that you would know is if you were staring at the phone. Does anyone know how to make that slider bar just turn the ringer off and keep the vibrate on like a normal phone? My buddies original droid slider bar works correctly and Moto tech doesn't have an answer for me. Thanks for any help on this in advance!
1Likes
