How to Backup and actually Restore Again
This is a discussion on How to Backup and actually Restore Again within the Droid X Help forums, part of the Droid X Discussion category; Running 4.5.621 and 2.3.4. The only ROMs I've played with are cyanogenmod and liberty that I got from the gingerbread ROMs section on this board. ...
Results 1 to 10 of 13
Thread: How to Backup and actually Restore Again
    Points: 990, Level: 16
    Level completed: 90%, Points required for next Level: 10
    Overall activity: 1.8%
    CosmicSunset's Avatar
    63431
    Dec 2012
    30
    Running 4.5.621 and 2.3.4. The only ROMs I've played with are cyanogenmod and liberty that I got from the gingerbread ROMs section on this board. I've been trying to do backups on and off since December using clockworkmod recovery but not one has ever actually restored successfully. They all fail the md5 sum check, which I can get past by blanking out the nandroid.md5 file and the recovery seems to work but on reboot I lock at the boot logo. I can usually access stock recovery but the stock zip "621_Stock_Rooted_kY-Signed" from "http://rootzwiki.com/topic/25017-roms-droid-x-45621-stock-rooted-stock-deodexed-modded-16-clockworkmod-flashable-updates-by-ky/" won't install due to signature failure.
    I'm using the "droid x" version of CWMR because that's what my phone says is it's model when I go into the settings, however I've tried the shadow "2nd init" option too with no luck. Also tried both options for CWMR version.
    Is there something simple I'm doing wrong? I've lost count of how many times I've SBF'd this thing trying to make recovery work so I can switch between ROMs already configured. That is kind of the point of the thing right, so we can get all our apps and settings set up and then save them and restore it all in a snap? Maybe I'm just missing the purpose of recovery.
    Points: 16,866, Level: 83
    Level completed: 4%, Points required for next Level: 484
    Overall activity: 99.9%
    Activity Award
    sd_shadow's Avatar
    56013
    South Dakota
    2,448
    284 times
    you don't need to start multiple threads, that's not helpful.
    don't use droid x bootstrap, it only was reliable on 2.2 froyo
    use modified droid x, or droid 3
    Install/Use Droid modified X or 3 Bootstrap
    Sent from my Amazon Kindle Fire using Tapatalk 2
    63431
    Dec 2012
    30
    are you talking about the wifi thread? didn't seem to have anything to do with this issue.
    I only have the Droid 2 Bootstrapper.
    Activity Award
    sd_shadow's Avatar
    56013
    South Dakota
    2,448
    284 times
    Quote Originally Posted by CosmicSunset View Post
    that's fine, but with separate threads lot of the same info will be repeated
    to restore a custom rom nandroid, ClockWork Mod needs to be updated from 2.0 to 5.0, easiest way to do that is install the modified Droid X or Droid 3 bootstrap
    you can update the droid 2 bootstrap with rom manager, but the update fails half the time, even though rom manager will say it worked, if you have verified you have 5.0 CWM, and restore is still failing, did you rename or move backup?
    63431
    Dec 2012
    30
    That seemed like it was going to work but I got an error in the end.
    here's the process I'm currently using.
    -SBF with slitaz CD
    -root with framaroot (gimli)
    -install ROM manager
    -install DroidXBootstrapperMod621
    -flash CWMR for droidx (gets me CWMR 5)
    -bootstrap and reboot to recovery
    -wipe data/cache, flash CM 7 and google apps
    -reboot and install some apps
    -flash recovery from ROM Manager (NO bootstrap!), boot into recovery and make a backup
    -reboot, install another app
    -use a text editor to clear the contents of nandroid.md5 for my backup (md5 sum check still fails on recovery without this)
    -boot into recovery and restore backup
    after all that I get the message "error restoring /system!" when I try to restore my most recent backup. Restoring a prior backup (from CWMR 2) succeeds but locks me at the boot logo.
    Now I need to SBF so I can actually use this thing for a minute. I'll try again later I guess. Any idea what I'm doing wrong?
    thanks a bunch for your advice btw.
    Activity Award
    sd_shadow's Avatar
    56013
    South Dakota
    2,448
    284 times
    SBF with slitaz CD
    ok
    ok
    recommend installing bootstrap first
    ok
    not needed, that's why I suggested using the modified bootstrap, it's already 5.0
    ok
    ok
    don't recommend using Rom Manager, don't flash cwm on custom roms they come with a hijack
    long press power>select reboot>recovery
    ok
    not sure how that will help
    restore md5 and try again
    Activity Award
    sd_shadow's Avatar
    56013
    South Dakota
    2,448
    284 times
    ok Pooka's cm7 comes (Pooka-CM4DX-GB-20120519.zip)
    comes with 2.5 cwm , i guess
    so probably should just use that, to create and restore nandroid backup
    if nandroid is made in 5.0 cwm use 5.0 to restore
    Activity Award
    sd_shadow's Avatar
    56013
    South Dakota
    2,448
    284 times
    another issue could be your sd card, may need to format it
    Memory Card Formatting - DROID X by Motorola
    63431
    Dec 2012
    30
    those tips really helped streamline the process but I still can't make a backup and then restore it due to the md5 checksum error. Your post seemed to indicate that I shouldn't be "working around" those errors by clearing the md5 file but I'm not aware of any other solutions and haven't been able to find a good explanation of what causes that mismatch. I'm not renaming my backups or even touching them between the backup and restore attempts.
    I tried restoring the backup I made yesterday which has it's .md5 cleared and it gave the same "Error while restoring /system!" message. I'm pretty sure restoring an older backup would lock me at boot logo again.
    just reloaded the thread and saw your last two posts. I'm using the exact ROM you referred to but have CWMR 5, maybe because I installed the modified X bootstrapper to get from stock ROM to CM 7. Not sure if it matters.
    My SD card is backed up so the only issue with formatting is copying everything back on (9 or 10 GB). What disk format does the Droid use anyway? I'm just wondering if it's possible and if there would be a speed advantage to formatting and reloading the SD card in a card reader directly on my computer rather than using the phone. It seems like reading/writing to the phone via USB is slow for some reason, at least when writing the SBF.
    thanks man
    63431
    Dec 2012
    30
    answered one of my own questions... right now the card is FAT32. guessing I should stick with that.
  1. Question about a backup restore
    By Chocobubba in forum Droid X Rescue Squad
    Last Post: 09-17-2011, 03:38 AM
  2. Replies: 14
    Last Post: 07-18-2011, 08:34 AM
  3. Trying to restore a backup
    By Lounatic in forum Droid X Help
    Last Post: 02-21-2011, 01:29 AM
  4. I want to restore a backup but...
    By AZLuvV in forum Droid X Rooted Issues
    Last Post: 12-30-2010, 01:06 AM
droid x wont flash rom
error #9 framaroot
framaroot error #9
framaroot error #9 fix
framaroot error 7
framaroot error 7 fix
framaroot error 9
framaroot error 9 fix
framaroot error explaination 7
framaroot error#9 fix
