GPS Help? Can never find location...
This is a discussion on GPS Help? Can never find location... within the Droid X Help forums, part of the Droid X Discussion category; So this is my first android phone, so I am a noob yes. But I thought GPS was suppose to be unlocked automatically, however, every ...
Results 1 to 6 of 6
  • 1 Post By thescreensavers
Thread: GPS Help? Can never find location...
    Points: 1,463, Level: 21
    riboflavins's Avatar
    605
    5
    So this is my first android phone, so I am a noob yes. But I thought GPS was suppose to be unlocked automatically, however, every time I use Google Maps and try to find location or do navigation, it never works, and cannot find my location? Is this due to the network being slow right now or is GPS locked on this phone without VZ nav? Any help would be much appreciated. Thanks!
    Points: 5,228, Level: 46
    Level completed: 39%, Points required for next Level: 122
    thescreensavers's Avatar
    268
    Miami,FL
    464
    48 times
    Your GPS on your phone may very well be off, if you did not change anything I believe the 2nd screen from the left from the home screen, just tap the GPS widget and it will turn on, you need to have a clear view of the sky, it may or might not work inside.
    If you want to add the widget long press the home screen or any of the extra ones, select Motorola Widgets and then find GPS Toggle and tap on it.
    Lightninrod likes this.
    Droid Does
    605
    5
    Got it, thanks!
    foreverXuser's Avatar
    1609
    43
    So my maps arent working... All i get are grey boxes no map.. any suggestions?
    Points: 1,206, Level: 19
    Level completed: 6%, Points required for next Level: 94
    Sartis's Avatar
    1429
    17
    Quote Originally Posted by foreverXuser View Post
    Make sure you have data reception?
    And everyone, make sure you enable assisted GPS in the location and security settings. It's a great feature, no reason it should be off.
    Points: 6,135, Level: 50
    Level completed: 93%, Points required for next Level: 15
    Overall activity: 2.6%
    500 Experience PointsCreated Album pictures250 Experience Points100 Experience Points7 days registered
    eric eakin's Avatar
    3548
    Ca
    1,071
    23 times
    Quote Originally Posted by thescreensavers View Post
    i also noticed if wifi is on gps will not work with navigation....
    Addicted to technology but don't always get it!
    X 2
Droid x gps slow
android never finds location
droid wont find location
droid x wont find gps
droid x2 will not find gps in google maps
droid x2 wont find gps
droid x2 wont find gps location
how come my droid x doesn't know my location
my phone can never find my location
phone never finds location
