droid x charges but will not boot
This is a discussion on droid x charges but will not boot within the Droid X Help forums, part of the Droid X Discussion category; i am have been having an issue with my x where it will randomly turn off and not boot back up, also same if i ...
Thread: droid x charges but will not boot
    i am have been having an issue with my x where it will randomly turn off and not boot back up, also same if i turn it off and try to turn it back on. thankfully i had found a post which was able to get me up and going again. DROID X won't turn on.. but will charge if i followed that process my x would boot up and be fine till i turned it off again. unfortunately now it will not turn back on no matter what. if i pull the battery and then plug it into my charger i can turn it on to the battery screen with a "?" in it. then if i put the battery it will charge to 100% after a while. i have tried my battery in my friend's x and it boots fine and has full charge. yet when i try to boot normally or even into recovery i get absolutely no response, the back light wont even turn on.
    unfortunately i got this phone from a friend a while ago so i cant go to vz for help.
    also iis rooted and flashed to the gingerbread ota from back when gingerbread was first released.
    and before asked i use a droid x usb charger with the wall adapter to charge it and i have never let it run to 0% battery, always get it plugged in by 10% at the lowest.
    Any help is much appreciated.
    Points: 26,735, Level: 97
    Level completed: 39%, Points required for next Level: 615
    Overall activity: 30.9%
    7,093
    338 times
    Are there any visible signs of damage (water, corrosion etc.) On the battery connector things under the battery?
    Sent from my XT926 using Xparent Cyan Tapatalk 2
    i am not seeing any signs of water damage, no.
    7,093
    338 times
    Won't turn on at all, not even bootloader?
    If that is the case I am at a loss. It may be hardware.
  1. Roaming charges?
    By jdubrolltide in forum Droid X General Discussion
    Last Post: 03-22-2012, 05:05 PM
  2. Data Charges
    By bhalbloom in forum Droid X FAQs
    Last Post: 12-18-2011, 10:21 PM
  3. What have you done with your X between charges today?
    By Tornlogic in forum Droid X General Discussion
    Last Post: 03-14-2011, 09:34 PM
  4. Market charges....
    By accordlayingkit in forum Droid X General Discussion
    Last Post: 01-11-2011, 10:59 AM
  5. Overage charges
    By obpmem in forum Droid X General Discussion
    Last Post: 08-31-2010, 08:40 PM
droid x will not boot
motorola 926 not turning on
motorola droid xt926 wont power on
motorola model xt926 won't turn on
motorola xt926 not turned on
motorola xt926 will not cut on
motorola xt926 won't turn on
motorola xt926 wont turn on
xt926 motorola battery at 100% not turning on
xt926 will not start
