Droid X .621 rooted HELP!!!
This is a discussion on Droid X .621 rooted HELP!!! within the Droid X Help forums, part of the Droid X Discussion category; I have a droid x rooted system info is as follows: SYSTEM: 4.5.621.mb810.verizon.en.US Android version: 2.3.4 Kernel: 2.6.32.9 Build: 4.5.1 Lemme start this by saying ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Droid X .621 rooted HELP!!!
    Points: 569, Level: 11
    Level completed: 38%, Points required for next Level: 31
    Overall activity: 1.0%
    3 months registered31 days registered100 Experience Points7 days registeredTagger Second Class
    N01F3AR's Avatar
    65152
    Apr 2013
    15
    Kernel: 2.6.32.9
    Build: 4.5.1
    Lemme start this by saying im an idiot for this one. ive had rooted phones before but new nothing of the droid x. i deleted some BLUR files in the process of spring cleaning. is there anyone out there with a rooted droid x that could send me the apk/odex files that say BLUR. I know i need the contacts and messaging ones but if possible would like to get ALL of them to make sure im covered. THanks in advanced to anyone that can do this for me. im using handcent to text right now but as far as looking at my contacts i force close out everytime i try to view one. and forget calling from my contacts list. i pretty much have to know any number i wanna call.
    N01F3AR's Avatar
    65152
    Apr 2013
    15
    Quote Originally Posted by N01F3AR View Post
    Kernel: 2.6.32.9
    Build: 4.5.1
    so now ive utterly Failed. cannot use phone cant even get to cantacts list. now i need to know how to get this thing into recovery mode and flash a stock ROM... please help
    Points: 51,689, Level: 100
    Overall activity: 99.9%
    fezrock's Avatar
    29044
    Asheville-ish
    10,465
    573 times
    Since you just got it, you won't lose much if you do a simple sbf. http://www.droidxforums.com/forum/sh...d.php?p=580701
    You want to do the easysbf. This will restore your dx to a virtual out-of-box state.
    Sent from my Galaxy Nexus using Xparent BlueTapatalk 2
    N01F3AR's Avatar
    65152
    Apr 2013
    15
    I'm not quite understanding the instructions in that page. So I basically hook up my phone to my laptop and run the program from the startup on my computer THEN hook up my phone in charge only usb mode? And this will restore my phone to out of box no root? Thanks for the patience. We all have to start somewhere lol
    N01F3AR's Avatar
    65152
    Apr 2013
    15
    downloaded droid_X_SBF-and-RootCD.iso is that the right file?? and do i have to go into recovery mode to flash it?
    fezrock's Avatar
    29044
    Asheville-ish
    10,465
    573 times
    As long as it is the. 621 cd you're good. Burn the iso, boot into cd on pc after a reboot, follow instructions. It's quite easy.
    N01F3AR's Avatar
    65152
    Apr 2013
    15
    I downloaded the file and burned it to cd I rebooted my laptop and hit the cd/dvd drive with the cd in it and it did nothing. I was in charge only mode with usb mode enabled. I followed out to the T.. Looks like hope is fading.
    Points: 28,020, Level: 98
    Level completed: 67%, Points required for next Level: 330
    7,093
    338 times
    The sbf did nothing or the CD didn't boot? You sure you burned it correctly? Not as a file but as a bootable image?
    Sent from my XT926 using Xparent Cyan Tapatalk 2
    N01F3AR's Avatar
    65152
    Apr 2013
    15
    Nope did it as a file. Thats my problem. How would I burn as boot image? Thanks for all your help btw.
    Points: 18,189, Level: 85
    Level completed: 68%, Points required for next Level: 161
    Overall activity: 99.6%
    sd_shadow's Avatar
    56013
    South Dakota
    2,449
    286 times
    http://neosmart.net/wiki/display/G/B...s+with+ImgBurn
    Sent from my XT862 using Droid X Forums
  1. Rooted Droid X, Now what?
    By JCizzle93 in forum Droid X Help
    Last Post: 10-28-2012, 03:41 PM
  2. Rooted Droid X hangs on blank screen using Droid X Bootstrap
    By netized in forum Droid X Rescue Squad
    Last Post: 02-07-2012, 03:56 PM
  3. Keep rooted Droid X2 or switch to rooted Thunderbolt
    By Daroadar68 in forum Droid X2 General Discussion
    Last Post: 11-20-2011, 01:21 AM
  4. Replies: 4
    Last Post: 06-19-2011, 04:32 PM
  5. Droid X 2.2 Rooted using Droid 2 root method
    By bmt626 in forum Droid X Hacks
    Last Post: 08-26-2010, 10:46 AM
4.5.621.mb810.verizon.en.us
boot into recovery droid x. 621
droid modified x 3
droid x .621
droid x 621
droid x framaroot
framaroot droid x
how do i find out what system my droid x originally had
modified droid x bootstrapper
restore usb mode, droid x
