Cannot root my Droid X
This is a discussion on Cannot root my Droid X within the Droid X Help forums, part of the Droid X Discussion category; Ive tried the magic md5 method with both thumb drive and cd boot from laptop and every time my laptop freezes on reboot with a ...
Results 1 to 10 of 20
Thread: Cannot root my Droid X
    Points: 996, Level: 16
    Level completed: 96%, Points required for next Level: 4
    codicamartin's Avatar
    64474
    Mar 2013
    26
    Ive tried the magic md5 method with both thumb drive and cd boot from laptop and every time my laptop freezes on reboot with a black screen and a flashing cursor. I would really appreciate any suggestions. I downloaded the md5, unzipped into documents (burnt and downloaded to thumb drive " and then attempted to reboot my laptop through cd and usb and its not working. Im trying it on a compaq presario cq60. Thanks guys, ive gotta get this figured out quick, wifes getting impatient with my time on the computer!
    Points: 17,020, Level: 83
    Level completed: 34%, Points required for next Level: 330
    Overall activity: 93.8%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    4,125
    437 times
    Moved to dx help thread.
    Points: 28,391, Level: 99
    Level completed: 3%, Points required for next Level: 1,609
    7,093
    338 times
    Did you check the md5 of the download to make sure it's good?
    Also, try a disk. Are you sure you're burning a bootable iso and not just a file?
    64474
    Mar 2013
    26
    Unfortunately im not certain how to check if the download is good or not. I found the link off this forum, it directed me to media fire where i downloaded it into winzip, then i unzipped the .iso file into my documents folder. Chances are it sounds like i may not have downloaded and burnt it properly. Thanks for your help and i look forward to your reply!
    7,093
    338 times
    The MD5 for a file is specific to each file and is almost impossible to duplicate except for with the same file... You will want to make sure the MD5 sum posted for that file matches what you get back. That will tell you if it was downloaded correctly or not.
    I use this. WinMD5 Free - Windows MD5 Utility Freeware download it, click the browse option and navigate to the file, double click it to open. (if it was zipped when you downloaded it, leave it zipped to generate the sum) It will give you the md5 sum back... You then copy and paste the one provided in the post and click verify.
    Do that with the file first, before worrying about if its burned correctly.
    The files and the md5 sums can be found here [How To] Root 4.5.621 with magic md5 (does not require Milestone SBF)
    T
    here are also instructions on how to burn to a disk in that thread under "instructions for windows."
    If anything is unclear, please just ask.
    Points: 18,395, Level: 86
    Level completed: 9%, Points required for next Level: 455
    Overall activity: 99.7%
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    if you burned file correct
    USB thumb drive will have a folder named root
    and some other files
    Sent from my XT894 using Droid X Forums
    64474
    Mar 2013
    26
    I GOT IT!!! Im now rooted and want to run the newest version of cyanogenmod for my X, but again, i have no idea where to find it and then run the ROM...ive done minimal research and it sounds like alot of booting and flashing. Could you help me out with this at all? BTW thanks for your previous help too!
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    first Install Droid 2 Bootstrap
    official cm is not compatible with DX 621
    cm7 is gingerbread 2.3.7
    cm9 is ics 4.0
    try Pooka's CM7
    [ROM] CM7-GBKernel .621
    MIUI DefX by Wizard0f0s
    LiquiKang , MiKangyUI v4/ , GummyKang, AOKP-Kanged?,, CMKang
    Points: 6,401, Level: 52
    Level completed: 26%, Points required for next Level: 149
    towbiz's Avatar
    41404
    1,095
    23 times
    And just to add: vxlr2.2 is a great rom that's already ported for 621 my opinion is its very smooth with great battery life and besides everything works enjoy
    sd_shadow's Avatar
    56013
    South Dakota
    2,450
    287 times
    http://rootzwiki.com/topic/38403-ope...roma-01242012/
  1. Root tools or root manager Droid X2....
    By Disention in forum Droid X2 Support
    Last Post: 12-28-2011, 05:14 AM
  2. [Root X] D3 1-click Root Method - Works on Droid X on 602
    By ejgilkey in forum Gingerbread Development and Hacking
    Last Post: 09-21-2011, 12:48 PM
  3. How do I root the newest OTA Gingerbread on my Droid X or how do I pre-root
    By mcbride305 in forum Gingerbread General Discussion
    Last Post: 07-01-2011, 12:59 PM
  4. Replies: 3
    Last Post: 12-06-2010, 09:33 PM
  5. Replies: 30
    Last Post: 08-21-2010, 02:41 AM
[root] framaroot, a one-click application to root droid x
cannot root
cant get magic md 5 method to unzip
droid x root
droid x wont root with framaroot
framaroot droid x
framaroot droid x doesn't work
how do i root my droid x?
how to root my droid x
unzip files on droid x root disc
