How do you change your home screens to way you want it.
This is a discussion on How do you change your home screens to way you want it. within the Droid X Help forums, part of the Droid X Discussion category; I just got my Droid x few days ago. And I am totally lost! I have seen Screen shots that people posts of there Home ...
Results 1 to 6 of 6
Thread: How do you change your home screens to way you want it.
    Points: 2,437, Level: 29
    Level completed: 92%, Points required for next Level: 13
    Overall activity: 1.4%
    DolphinxManiax23's Avatar
    7637
    Cleveland, Ohio
    166
    I just got my Droid x few days ago. And I am totally lost! I have seen Screen shots that people posts of there Home screens. I know alot of you use Launcher Pro. But how does that work? I installed it and it made my home screen different it only gave me 3 screens instead of 7 what I had. And the Icons I had were gone also. But it wont let me open Launcher Pro? How do I get this to work to move things around how I want it to look?
    Like for my one home screen I wanted like few icons on left side and a picture on right side and some Icons on top. I seen a screen shot that someone did that. But how do I do that?
    Ive been using the Marketplace alot. I just need to know how to get my home screens the way I want it to look!
    If anyone can please help me out some...Thanks!!
    Smitty6750's Avatar
    5569
    leakesville ms
    174
    If u using launcher pro u can go in preferences and chose up to seven side screen. If u wanna add icon from ur drawer to ur on-screen simply long press on it then it will move. If u like the nice weather and clock widget a lot of ppl have check out beautiful widgets very great app and I recommend it. If u wanna change ur wallpaper I suggest ledge very good wallpaper app plus it has a lot of simple ringtones. To change ur wallpaper long press on empty spot on ur screen a spot will come up giving u option between widgets wallpapers shortcuts and other things. Just try some stuff play around with it and before u now it ur DX will be all custom the way u like it.
    Droid x rooted
    oc'ed 1.15
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Hello and welcome to the forums!!
    To open LauncherPro (if it is presently the home app you are using), hard menu key, preferences - you are now into the settings - you can select how many home screens you want, which will be your default, hide notification bar, hide icon text, dockbar settings, etc...
    If you do not have LP open, click on your home key and you should see a popup box - you can choose which home app you would like to have opened. If you set LP as your default, you will need to download an app from Home Switcher from the Market - it will allow you to toggle back and forth between your home apps...
    To move items around on the screen - long press till you feel a vibrate and then drag with your fingertip - when you lift your fingertip, it will drop into place. If you want to delete an icon or widget, long press and drag towards the bottom of your screen you should see a red trash can - both the icon or widget and trash can have to turn red - this only deletes the icon / widget from the homescreen not the phone (unless you are prompted with do you wish to uninstall - if you select yes, it will uninstall).. To add widgets to your home screens, long press, popup box appears and select widgets (you should also see other options here as well that you can use to customize your homescreens)....Once you select which widget, it will either add or take you to the configure settings to complete the widget setup...
    Hope this helps - again welcome and enjoy!!
    250 Experience Points31 days registeredCreated Album pictures100 Experience Points7 days registered
    Dansl's Avatar
    1870
    54
    Zedge not ledge
    Sent from my DroidX...
    Smitty6750's Avatar
    5569
    leakesville ms
    174
    Dang predictive lol sry zedge
    Droid x rooted
    oc'ed 1.15
    7637
    Cleveland, Ohio
    166
    Thanks for the help!!! I hope I can figure it out..
    Now since we have to buy beautiful Wedgets can we pay these Apps with Paypal or anything like that? Or does it have to go right on your Phones bill?
  1. Screenshots of your Droid X home screens
    By Garemlin in forum Droid X Themes
    Last Post: 12-01-2014, 06:07 AM
  2. Change Home Dock Screen?
    By zoomzoom9 in forum Droid X General Discussion
    Last Post: 08-05-2010, 10:02 AM
  3. Change Number of Home Screens w/ Stock Home?
    By AR1Z0N4 in forum Droid X Help
    Last Post: 08-04-2010, 07:08 AM
  4. Defective screens?
    By mflynn in forum Droid X General Discussion
    Last Post: 07-20-2010, 11:05 AM
  5. How to get icons on certain screens
    By rubi22 in forum Droid X General Discussion
    Last Post: 07-16-2010, 04:42 PM
change home screen on droid
droid change home button to different screen
droid thunderbolt screen changed want to change it back
how do i change home for droid
how do i change homepage on my droid
how do i change my droid x screen
how to change droid home screen
how to change home screen on droid x
how to change the home screen on droid x
how to change your home screen settings on a driod revolution
