Droid x screen replacement issues! Help please!!
This is a discussion on Droid x screen replacement issues! Help please!! within the Droid X Help forums, part of the Droid X Discussion category; Hi. i just bought a droid x and i used it for a couple of days and suddenly there were horizontal lines across the screen ...
Results 1 to 8 of 8
Thread: Droid x screen replacement issues! Help please!!
    Points: 9, Level: 1
    Level completed: 17%, Points required for next Level: 41
    Tagger Second Class
    iks13's Avatar
    63465
    Dec 2012
    Exclamation Droid x screen replacement issues! Help please!!
    Hi. i just bought a droid x and i used it for a couple of days and suddenly there were horizontal lines across the screen of my droid x. So i decided to replace it and got a new lcd. I took apart the droid x (disconnected all cables and connectors) the antenna cable and everything. i got to the lcd and carefully took that off and replaced it. I put the metal tab on top of the little spring thing on the case and connected everything back together. I turn it on and everything seems to working fine vibration and lights) the screen lights up but doesnt show the motorola sign or any color at all even slide the phone to unlock it and it vibrates. I would really appreciate the help. and will it be better if i post pictures?? thanks
    ~IKS~ =^.^=
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Its obviously under power, but not picking up the software. Odd.
    Seeing as how you took it apart my only guess to fix it is to take it back apart again and make sure everything is attached.
    Tapp'd from one of my Nexus Devices
    FreeMyMoto!!!
    If you need help PM me!!!
    Points: 9, Level: 1
    Tagger Second Class
    iks13's Avatar
    63465
    Dec 2012
    Thanks ill open it up again and this time ill take pics and post them asap
    ~ IKS ~ =^.^=
    My screen did this too...make sure the LCD cable is all the way pushed in place. also, let me know if you're having brightness issues...I can't figure out how to fix that part...
    Hello everyone, I have a droid x issue. I recently got my phone wet and immediately pulled the batter and dried it off. When i turned it back on later that day it had 2 massive black spots so I got a new digitizer/screen. When I pulled the phone apart, I noticed black adhesive on the ribbon cable connectors and it was very hard to get off. After putting in the new digitizer/screen I put it all back together...the screen didn't come on. Everything else was on, even tried test calling and sure enough it rang + vibrated. Any tips on how to fix this issue?
    Points: 18,045, Level: 85
    Level completed: 39%, Points required for next Level: 305
    sd_shadow's Avatar
    56013
    South Dakota
    2,449
    286 times
    You replaced both LCD (black screen) and digitizer (clear glass)?
    It's possible that new LCD was bad or wrong version.
    Should be a version number on both new and old.
    Take it apart and see if a connection or cable looks bad, try old LCD again.
    sd_shadow.
    Where would the model number be located And where can i get one for a good price?
    The current (new) screen was ordered off of Amazon.
    sd_shadow's Avatar
    56013
    South Dakota
    2,449
    286 times
    Some of the other droids have different versions, doesn't look like the X does.
    There are several different sellers on ebay or Motorola Droid X LCD Screen Replacement
  1. Notes about screen replacement Droid X
    By scuzzo in forum Droid X General Discussion
    Last Post: 09-04-2012, 09:34 PM
  2. Droid X Replacement Screen Issue
    By yaqngie in forum Droid X Help
    Last Post: 08-12-2012, 02:24 PM
  3. Replacement issues
    By Anthony 23 in forum Gingerbread General Discussion
    Last Post: 08-04-2011, 11:27 AM
  4. Droid X Screen Replacement
    By ddzado in forum Droid X General Discussion
    Last Post: 06-14-2011, 10:15 AM
  5. Issues where you had to get a replacement DX?
    By PA452 in forum Droid X General Discussion
    Last Post: 09-08-2010, 09:40 AM
droid x replacement screen
droid x replacement screen not working
droid x screen replacement
droid x screen replacement isses
droid x screen replacement issues
droidx screen relacement
how to replace droid x screen
replace screen on droid x
replacement screen for droid x
