Play Store Always Crashes Instantly on Opening
This is a discussion on Play Store Always Crashes Instantly on Opening within the Droid X Help forums, part of the Droid X Discussion category; I've been looking for a solution to the problem stated in the thread title (that is, the play store app [and the original stock market ...
Results 1 to 10 of 20
Like Tree4Likes
Thread: Play Store Always Crashes Instantly on Opening
    Points: 755, Level: 14
    Overall activity: 1.7%
    skyler544's Avatar
    55055
    Jan 2012
    15
    I've been looking for a solution to the problem stated in the thread title (that is, the play store app [and the original stock market app, and an absurd number of different versions of the store I downloaded from various android communities] refuses to stay open for more than a second or two, at which point the force close message flashes onscreen, disappears, and the market closes.) for around two weeks now, and I've had absolutely no dice. I can't even seem to find a record of anyone else having the same issue. I found loads of threads with similar issues, but all the fixes (clear cache and data, install a different market version, factory reset, etc.) seem to do absolutely nothing. I even went as far as backing up my CWM backups and formatting my sd card, and nothing works. For a little context, I'm currently running CyanogenMod-7.1.0-DROIDX-KANG with android 2.3.7. I was originally using this ROM, but when I found out that the CyanogenMod team released a working ICS CM9 ROM for the Droid X, I flashed that no problem and had fun for a couple days. My X is in poor shape though and runs extremely slowly with that ROM, so I attempted to SBF back to stock to get back to CM7, and that's when things went completely to hell. After a lengthy process, I finally got my X on stock .602 GB and flashed CM7. Things went swimmingly until I tried to get the ICS theme for ADW launcher, and that's when my Play Store stopped working. Now, even after an sbf to .602 (on which the Play store didn't work) and another flash back to CM7, the Play Store crashes instantly each and every time I open it UNLESS it's in airplane mode, where it will sometimes stay open on the loading screen until connection is restored and sometimes it crashes just like if I have a connection. I hope I've provided enough details to get this figured out, because obviously an android phone without app capability is pretty worthless.
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Sounds like you have a bad gapps to me
    Tapp'd from one of my Nexus Devices
    FreeMyMoto!!!
    If you need help PM me!!!
    skyler544's Avatar
    55055
    Jan 2012
    15
    I should've mentioned that I've tried redownloading the gapps twice now, and that all of the gapps besides the play store work totally fine
    Points: 8,886, Level: 63
    Level completed: 46%, Points required for next Level: 164
    Coronado is dead's Avatar
    22827
    554
    Silly question, but dis you clear the play store data in the Applications menu? I had this issue before and that fixed it.
    skyler544's Avatar
    55055
    Jan 2012
    15
    I did that yes, and I have tried all of the other fixes I've found and nothing has helped.
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Let's see.
    Okay so if you sbf then wipe data/factory reset it doesn't help?
    I have an idea. Let me look really quick
    FreeMyMoto!!!
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    http://db.tt/fn5GFJvh
    Manually install this using a root explorer (/system/app). Change the permissions to what the rest of them are (rw-r--r--)
    Then reboot.
    Then reboot to recovery.
    Wipe cache and dalvic, Fix permissions, reboot.
    Then wipe the apps data and let it update on its own. See if that does anything.
    FreeMyMoto!!!
    skyler544's Avatar
    55055
    Jan 2012
    15
    I'm still getting a force close, although now I can actually click the "force close" button if I'm fast enough. before it disappeared immediately, just showing up for long enough for me to guess that it must be a force close prompt. I'm away from my real computer, stuck with a laptop sans cd drive, so I'm in the process of downloading the sbf file for one more try on a factory reset
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    This makes no sense at all. Do you have ROM manager installed? Try and run a fix permissions through that.
    FreeMyMoto!!!
    skyler544's Avatar
    55055
    Jan 2012
    15
    Tried that and now the market force closes even when I don't open it
  1. Google Play Store
    By sparker781 in forum Droid X Help
    Last Post: 10-27-2012, 10:14 AM
  2. Replies: 4
    Last Post: 04-15-2012, 05:14 PM
  3. Does Droid X not have Google Play Store?
    By efromthev in forum Droid X General Discussion
    Last Post: 03-26-2012, 07:53 AM
  4. Google Play Store
    By SLASHX in forum Droid X Help
    Last Post: 03-24-2012, 10:13 AM
  5. Indianapolis VZW store opening at midnight
    By Jaxidian in forum New Member Introductions & Site Assistance
    Last Post: 07-14-2010, 02:32 PM
cyanogenmod play store crash
google play opens and closes
google play store closes immediately
google play store crashes on startup
google play store opens then closes
play store closes
play store crashes
play store force closes everytime i open it
