Charging Dilema
This is a discussion on Charging Dilema within the Droid X Help forums, part of the Droid X Discussion category; Well, I havent been on here in a while because i havent had any problem with my Droid. And, now I have a slight problem. ...
Results 1 to 8 of 8
Thread: Charging Dilema
    Points: 3,188, Level: 34
    Level completed: 92%, Points required for next Level: 12
    Overall activity: 1.2%
    naidanirt's Avatar
    38544
    367
    Charging Dilema
    It happens when I charge my phone in an outlet, it will say "Charging <percent here>" but then 10 seconds later it stops, but when I plugin my phone into my computer it will charge perfectly fine.
    Another issue is my phone will Power down with 5% of the battery remaining, but it will act as if it has 0% battery when I try to turn it on, however if I plug in my phone to charge. It instantly starts up with the alert of 5% remaining and will continue to charge until full.
    Any suggestions on why this is happening?
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    How old is the charger? That sounds to me like whst the issue is.
    Tapp'd from one of my Nexus Devices
    FreeMyMoto!!!
    If you need help PM me!!!
    naidanirt's Avatar
    38544
    367
    the charger is about as old as my phone ( 1 3/4 of a year?)
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    I would try and buy a new one. And see if that works. If it doesn't, ill be surprised, and it means its the charging port and its insurance time.
    FreeMyMoto!!!
    Points: 28,483, Level: 99
    Level completed: 9%, Points required for next Level: 1,517
    Overall activity: 37.7%
    7,093
    338 times
    Shouldn't be the port if it still charges from the computer.
    Points: 17,164, Level: 83
    Level completed: 63%, Points required for next Level: 186
    Overall activity: 99.8%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    4,125
    437 times
    Could be the battery too, usb charging method charges slower and actually gives a better charge than using an outlet and if the battery is going out, it may not accept the faster charge. Just an idea....
    Ridin the Mystic jellybean unicorn on my blazing SG3
    Points: 4,713, Level: 43
    Overall activity: 1.6%
    newmanx4's Avatar
    34469
    703
    29 times
    And that issue with shutting down is normal. I believe its actually 4% where it shuts down. It doesn't have enough power to boot up at that point.
    Sent from my Black Iced X
    Points: 6,294, Level: 51
    Level completed: 72%, Points required for next Level: 56
    jaguarxt's Avatar
    28099
    166
    9 times
    Getting a new battery never hurts.
    But I found that charge's USB connector, that connect to your device, get worn down, becomes loose and don't connect well. So you may see starting charging then doesn't charge, because of the charger's USB loose connector.
    Get a new charger.
    Summary of Devices
    Device: Samsung Galaxy Note 2 (SGH-T889)
    Android Version: 4.1.1 Jelly Bean
    Build: JRO03C.T889UVALL4 (Rooted)
    Device: Motorola DROID X
    Android Version: 2.3.3 Gingerbread
    Build: 4.5.605.Accurate_Battery (Rooted)
  1. Charging LED Fix
    By Pharylon in forum Cyanogenmod
    Last Post: 01-26-2012, 06:54 PM
  2. Charging
    By whetrick2 in forum Team Liberty
    Last Post: 12-28-2011, 11:14 AM
  3. Can someone assist me with this dilema
    By Nerdslogic in forum Droid X Apps
    Last Post: 06-05-2011, 01:22 PM
  4. Replies: 3
    Last Post: 12-05-2010, 06:37 PM
  5. My small dilema
    By Bill in forum Droid X General Discussion
    Last Post: 07-28-2010, 03:06 PM
