Droid X still reboots even after a Factory reset
This is a discussion on Droid X still reboots even after a Factory reset within the Droid X Help forums, part of the Droid X Discussion category; I posted a thread maybe a week or two ago asking how to fix the problem with my Droid X (2.3.4 [4.5.621]) rebooting randomly and ...
Results 1 to 7 of 7
Thread: Droid X still reboots even after a Factory reset
    Points: 1,753, Level: 24
    Level completed: 53%, Points required for next Level: 47
    Overall activity: 0.8%
    JCizzle93's Avatar
    39230
    80
    I posted a thread maybe a week or two ago asking how to fix the problem with my Droid X (2.3.4 [4.5.621]) rebooting randomly and the only answer I got was to clear the cache or something and to factory reset. I did both of those things and it still rebooted at random times and its really annoying. I dont know how to figure out the cause and I want it to stop. Can anyone help? Also its not rooted and I refuse to factory reset again because redownloading all my apps is frustrating and took all day to do.
    EDIT: Forgot to mention, it reboots sometimes when downloading an app from the market or when im about to reply to a text message.
    Points: 17,886, Level: 85
    Level completed: 8%, Points required for next Level: 464
    Overall activity: 99.8%
    6,216
    138 times
    Could be an app... Did it reboot soon after doing the factory reset or only after you reinstalled everything?
    You could try an SBF. Just make sure it the same system version you are using and you shouldn't lose anything.
    Otherwise if it still does it on stock after a factory reset/sbf it could be a hardware issue. If you aren't willing to root and/or ROM then I'm afraid there isn't much we can do to help you.
    JCizzle93's Avatar
    39230
    80
    After I reinstalled everything it happened again. I think it might be the app "No Root Screenshot it" I uninstalled it so hopefully thatll fix it but idk. I dont know how to root and it seems complicated.
    6,216
    138 times
    It's really not so bad. If it was the app then great. If not and you wanna give rooting a go then just let us know. We can make it as least complicated as possible. If you are on 621 its only a cd you burn and boot the computer from. If it's previous versions then it's even simpler than that.
    JCizzle93's Avatar
    39230
    80
    It wasn't "No Root Screenshot it" =/ I don't know what the issue is. So i guess can someone show me how to root?
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    Instructions in the thread.
    Sent from my Black Iced X
    JCizzle93's Avatar
    39230
    80
    I forgot to mention, sometimes it reboots when I try downloading an app from the market or when im about to reply to a text. I don't know if that helps but i forgot to mention that in the original post.
  1. Replies: 6
    Last Post: 10-04-2011, 07:35 PM
  2. Rooted Froyo Droid X factory reset
    By daroga in forum Droid X FAQs
    Last Post: 07-30-2011, 01:31 PM
  3. Factory reset a rooted Droid X2?
    By theguru1974 in forum Droid X2 Hacks
    Last Post: 06-25-2011, 09:24 PM
  4. Factory Reset Droid X wont install GB.
    By Orion_2kTC in forum Droid X General Discussion
    Last Post: 06-02-2011, 08:19 AM
  5. DROID X - Factory Data Reset
    Last Post: 07-15-2010, 02:06 AM
droid x 2.3.4 randomly reboots
droid x reboot
droid x2 still rebooting after dat/factory reset
phone still rebooting after factory reset
reboot a droid x
restarts even after factory reset
rooted droid still reboots after factory reset
stock rooted droid x reboots
what to do after fratory reset droid x2
xoom still reboots after factory recovery
