Well I'll get back to you 2morrow.....Heading to bed
This is a discussion on I really screwed myself within the Droid X Help forums, part of the Droid X Discussion category; Well I'll get back to you 2morrow.....Heading to bed...
Well a minor issue here....When trying to SBF I looked at my phone this morning and its saying "Battery Low" and "Code Corrupt". I am pretty sure that its because the battery died. UGH am I screwed here?
do you happen to have an external charger, spare battery, or someone who has a battery you can borrow? If not you may be able to bring it to verizon and they *may* charge it for you.
Also if u leave it plugged in with the green light on for about 20 min u should be be able to get a small charge to get back to Bootloader
Fart Blood
68 88 32 45 32 79 67 32 49 46 50 32 103 104 122 32 71 66 32 118 46 48 53 13 10
Well the battery is not getting any type of charge....The screen is still blinking what it was before. I do not have an external charger and the closest Verizon Wireless store is like 2 hours away....Well I guess I'll use my parents spare cellphone!!
Im pretty sure there is a workaround. It has to be plugged in to a wall charger. I'm sort of guessing here but power the phone down, pull battery, plug charger in to WALL outlet, other end in to phone, replace battery, and see if you can get it going. May have to pull battery a couple of times. I'm pretty sure that's not exactly it, but I know there are posts somewhere that explain a method like this that will work
Sent from my cm_tenderloin using Tapatalk 2
Well after leaving it on for about 30 minutes I am still at the boot loader screen still the same message...Anyone got any other ideas??
a new battery from amazon? they are rather cheap now...
tap'd from the Gnex
You did those steps from a powered off state? Or did you power it back up first? This should be done from without turning it back on. I'll Google this issue and check some threads. I damn well know I've seen this issue posted before. Someone has got to know the correct procedure.
Sent from my DROID BIONIC using Tapatalk 2
With the phone in a powered off state when i put the battery in it automatically powers on to the boot loader screen
