stuck at boot logo when trying to boot into cwm recovery
This is a discussion on stuck at boot logo when trying to boot into cwm recovery within the Droid X Help forums, part of the Droid X Discussion category; im sure and congrats on the smom again...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: stuck at boot logo when trying to boot into cwm recovery
    Points: 195, Level: 3
    Level completed: 90%, Points required for next Level: 5
    Overall activity: 4.1%
    31 days registered100 Experience Points7 days registered
    wavecrasher's Avatar
    62019
    Oct 2012
    Right around the the first S in Tennessee on the map
    17
    Points: 187, Level: 3
    Level completed: 74%, Points required for next Level: 13
    Overall activity: 1.6%
    volfan537240's Avatar
    61782
    Sep 2012
    14
    Go vols brother! Lol that Newman guy is ok... for a bammer. Jk, thanks for the help Newman! I was able to reboot into recovery with d2 bootstrap now. Question is, can I do it with cwm now or will I have the same problem all over again?
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    What ROM are you running? On 2nd init ROMs press and hold the power button til the power menu appears and select reboot->reboot recovery. Otherwise you can reboot recovery in ROM Manager. If Goose was right about insufficient space for CWM to install then you need to go back in ROM Manager and Update Latest Clockwork again.
    Sent from my Black Iced X
    61782
    Sep 2012
    14
    Im on the 605 radio fix. I was on cm9 but couldn't get the camcorder to work even with lg camera and wifi tether wouldn't work as well as a few other apps so I sbf'ed back to froyo and flashed the 15p radio fix 605. Im interested in cm7 if it has no bugs but I found so many different threads on it, I couldn't tell which one had the latest updated link.
    newmanx4's Avatar
    34469
    703
    27 times
    If you want CM7 you need Pooka's build.
    http://rootzwiki.com/index.php?/topi...rge-While-Off)
    If the links in the OP don't work go through the last 10 or so pages and you'll find them.
    61782
    Sep 2012
    14
    Cool! Thanks for all the help!
  8. #17
    Points: 7,202, Level: 56
    Level completed: 26%, Points required for next Level: 148
    Overall activity: 28.3%
    1,340
    78 times
    Quote Originally Posted by volfan537240 View Post
    BTW what I recommend regarding CWM as I know it works on the 15p is after you nuke the extra pre-install just use the outdated CWM that bootstrap per installs as sometimes updating via ROM Manager can break it again for whatever reason. Once you GET to another ROM then update CWM to the proper Droid X (2nd-init) option and you should be a-ok.
    Tapped from my jelly-beaned d2vzw
  1. Stuck at boot logo
    By craig7220 in forum Droid X Rooted Issues
    Last Post: 10-16-2011, 11:15 PM
  2. Replies: 4
    Last Post: 10-15-2011, 11:42 AM
  3. Stuck at boot logo. Help!
    By fartripper67 in forum MIUI
    Last Post: 09-18-2011, 01:08 AM
  4. Droid X - Stuck at M logo, Won't boot into recovery HELP!
    By aloha312 in forum Droid X Rescue Squad
    Last Post: 09-02-2011, 09:44 PM
  5. Boot stuck at M logo. Help???
    By st3rdroids in forum Droid X Rooted Issues
    Last Post: 04-11-2011, 08:35 PM
boot logo cwm
cwm recovery stuck in boot logo
cwm recovery won't boot
cwm stuck at boot logo
droid x won't boot to recovery from cwm
how to boot into cwm recovery
kindle fire stuck at boot logo
kindle fire stuck on boot logo
kindle stuck on boot logo
tried to install kindle fire factory rom and now i'm stuck at boot logo
