Home screen has moved
This is a discussion on Home screen has moved within the Droid X Help forums, part of the Droid X Discussion category; I don't know how this happened, but my home screen has moved over two screens! How do I get it back the way it was?...
Results 1 to 10 of 10
Thread: Home screen has moved
    Points: 4,989, Level: 45
    Level completed: 20%, Points required for next Level: 161
    Craig225's Avatar
    35008
    364
    Points: 17,950, Level: 85
    Level completed: 20%, Points required for next Level: 400
    Overall activity: 99.8%
    6,237
    138 times
    Correct me if I'm wrong but when your phone is sitting at the home screen don't you just press the home key again and select your screen? If it's not the home key, try the back button.
    Points: 41,312, Level: 100
    Overall activity: 99.9%
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    13,640
    162 times
    What are you using for a launcher ?
    tap'd from the Gnex
    Craig225's Avatar
    35008
    364
    Quote Originally Posted by DirtyDroid View Post
    GO Launcher EX
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    13,640
    162 times
    Haven't used it...bit if its what I'm thinking...hit the menu>settings>preferences> there should be a manage home screens..then the yellow star can be moved to the home screen you want ....I'll try to install it on a bit to see exactly...but I think that is what you are referring to..yea?
    tap'd from the Gnex
    Craig225's Avatar
    35008
    364
    Home screen moves when I unlock device
    This never happened before, but now when I unlock my Droid X, that motion somehow pushes my home screen down two screens. Then I have to swipe twice to get it back. How do I deal with that?
    I am not rooted.
    I have Android version 2.3.4.
    I use GO Launcher EX
    Points: 8,716, Level: 62
    Level completed: 89%, Points required for next Level: 34
    Overall activity: 99.6%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    3,049
    125 times
    I would go into settings,manage apps and find go launcher, clear cache and data, or even uninstall and install it again. If I recall, pinch the screen with your fingers to see all your pages, the long press in the one you want as your home page, I think there is also a option in settings for go launcher that you can have it return to homescreen after every screen unlock, haven't used go launcher in a long long time.
    teleported from MI Wizardry UI DXtreme
    Craig225's Avatar
    35008
    364
    Quote Originally Posted by clothednblack View Post
    ...haven't used go launcher in a long long time.
    Thank you for the suggestion. May I inquire as to what launcher you do use? Maybe it is better than mine.
    51337
    Nov 2011
    Smith river CA
    3,049
    125 times
    https://play.google.com/store/apps/d...=com.tsf.shell
    Its all just a matter of taste and preference, they all have pros and cons.
    Themer
    Points: 6,940, Level: 54
    Level completed: 95%, Points required for next Level: 10
    Overall activity: 14.5%
    250 Experience PointsCreated Album pictures100 Experience Points31 days registered7 days registered
    stryker's Avatar
    30941
    PA
    586
    27 times
    Quote Originally Posted by Craig225 View Post
    If your using go launcher, hit menu/edit/ and choose which screen you want to be your home screen, you can also add and re arrange screens also. Make sure your are running the latest version also. Go launcher is one of the best launcher out there.
    -=(.stryker.originals.)=-
    Typed from my laptop.
  1. different lock screen and home screen
    By cw0974 in forum Droid X Help
    Last Post: 07-21-2011, 06:50 AM
  2. Replies: 2
    Last Post: 06-14-2011, 11:19 AM
  3. Replies: 7
    Last Post: 06-05-2011, 08:55 PM
  4. Home screen different than locked screen..
    By briiibabyy in forum Droid X Help
    Last Post: 03-08-2011, 06:04 PM
  5. Name on Home Screen or Lock Screen?
    By CrashF16 in forum Droid X Help
    Last Post: 09-06-2010, 07:33 AM
android home page moved
android home screen moved
android home screen moved?
display time droid x home screen
home page moved android
my android home page moved
my homescreen moved android
