My droid x I can not help install a custom rom.
This is a discussion on My droid x I can not help install a custom rom. within the Droid X Help forums, part of the Droid X Discussion category; Hello such friends, I'm from Peru, I have a droid x. 621 (rooted LIVECD..1KDStaz_MX_4.5.604...) with root and cwm: ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ System version: 4.5.604.MB809.ACG-nTelos.US Model version Milestone ...
Thread: My droid x I can not help install a custom rom.
    Points: 85, Level: 1
    Level completed: 70%, Points required for next Level: 15
    Overall activity: 0.8%
    nike1973's Avatar
    61848
    Sep 2012
    System version:
    Model version
    Milestone X
    Android Version
    2.3.5
    Baseband Version
    BP_C_01.09.15P
    Kernel version
    2.6.32.9geadffa3mcbk83@il93inxdroid08 #1
    Build number 4.5.1_57_mx2-34
    Eri version
    5
    PRL version.
    58012
    Excuse my English I speak Spanish but I will explain it as easy as possible: D. Thank you.
    CWM 5.0.2.0-->wipe/data factory reset.-->wipe cache-->format devil-cache-->format system-->format data-->format cache-->install zip from sdcard-->Liberty 3.20 rom--> Bootloader 30.03 Err:....
    CWM 5.0.2.0-->wipe/data factory reset.-->wipe cache-->format devil-cache-->format system-->format data-->format cache-->install zip from sdcard-->ApeX 2.0 (RC4)--> Bootloader 30.03 Err:....
    Please I need all the help possible. Thank you.
    Points: 3,147, Level: 34
    Level completed: 65%, Points required for next Level: 53
    Overall activity: 2.7%
    newmanx4's Avatar
    34469
    703
    27 times
    Your steps for flashing the ROM look to be in order. I'm wondering about the ROMs you are trying to flash. Blur based ROMs had to be patched to work with 621. Can you post the links to where you got these ROMs?
    Here's where you need to download them. If you're on Milestone 604 you also need to flash the 621 kernel back to the phone. It's in the first post. Link at the bottom of the first post takes you to the ROMs.
    [ROMs] Multi-ROM Thread - Blur-Based ROMs for those on .621/.604!
    Sent from my Black Iced X
    nike1973's Avatar
    61848
    Sep 2012
    Quote Originally Posted by newmanx4 View Post
    Hello, thanks friend, I can normally install a rom. Sorry but I could recommend a rom that has HDMI and my battery last longer? Thank you.
  1. Replies: 26
    Last Post: 06-14-2011, 08:50 PM
  2. How to install custom boot animation
    By Flazell in forum Droid X Hacks
    Last Post: 02-13-2011, 07:38 PM
  3. Can you install a custom rom from another custom rom?
    By anto4114 in forum Droid X Hacks
    Last Post: 11-02-2010, 12:09 PM
best custom rom for my droid x 2
droid x roms
flash custom rom droid x on ntelos
