Liquid ICS, anybody know how to delete on screen keys.
This is a discussion on Liquid ICS, anybody know how to delete on screen keys. within the Droid X Help forums, part of the Droid X Discussion category; I have a couple of apps that won't run in the correct resolution. Pretty sure wiping the keys away will fix it, can't find it ...
Thread: Liquid ICS, anybody know how to delete on screen keys.
    Points: 1,030, Level: 17
    Level completed: 30%, Points required for next Level: 70
    Overall activity: 3.2%
    cooksta3276's Avatar
    54609
    Jan 2012
    52
    I have a couple of apps that won't run in the correct resolution. Pretty sure wiping the keys away will fix it, can't find it in any menu options. Thanks.
    Points: 1,297, Level: 19
    Level completed: 97%, Points required for next Level: 3
    Overall activity: 1.0%
    V1215's Avatar
    35087
    56
    System Setting>Interface>Navigation
    ... I believe.
    54609
    Jan 2012
    52
    Thanks...got it. At first I didn't bother, thinking that was Google Navigation options. LoL
  1. Replies: 3
    Last Post: 08-16-2014, 12:12 AM
  2. default home screen keys
    By dustmanz23 in forum Droid X Help
    Last Post: 09-07-2011, 02:45 PM
  3. Change permanent home screen keys?
    By ANJay in forum Droid X2 General Discussion
    Last Post: 06-21-2011, 12:28 PM
  4. Hard Keys On Screen?
    By onehandsolo in forum Droid X General Discussion
    Last Post: 02-25-2011, 03:45 PM
  5. Liquid in middle of screen under normal use?
    By BlitzeDonX in forum Droid X General Discussion
    Last Post: 01-05-2011, 08:20 AM
droid x liquid ics
droid x liquid on screen
liquid ics remove softeys
liquid ics soft keys
liquidics we
