battery removal cause lost data?
This is a discussion on battery removal cause lost data? within the Droid X Help forums, part of the Droid X Discussion category; Will I lose data if my battery is removed for any length of time fron my DROID X?...
Results 1 to 2 of 2
Thread: battery removal cause lost data?
    Points: 509, Level: 10
    Level completed: 18%, Points required for next Level: 41
    Overall activity: 0.7%
    sundaz2012's Avatar
    56801
    Mar 2012
    9
    Points: 17,985, Level: 85
    Level completed: 27%, Points required for next Level: 365
    Overall activity: 99.8%
    6,246
    138 times
    No, pulling the battery should have no effect on data.
  1. **Solution for lost data due to 2.3.5 sbf**
    By trizzle in forum Droid X Help
    Last Post: 03-26-2012, 11:10 PM
  2. Data connection lost!
    By idontliketolose in forum Gingerbread Help
    Last Post: 11-17-2011, 11:05 PM
  3. Battery Icon Removal
    By WillMiii in forum Gingerbread General Discussion
    Last Post: 05-03-2011, 02:25 PM
  4. Battery Removal
    By sublime118 in forum Droid X Help
    Last Post: 08-20-2010, 08:15 PM
  5. battery removal?
    By craSSh in forum Droid X Help
    Last Post: 08-02-2010, 11:50 AM
droid forums will i lose my contacts by removing the battery
effect of batttery removal on android
galaxy remove battery lose data
remove battery lose time and date android
replace android battery lose data?
will i lose data by removing droid battery?
will i lose data by removing the battery from my droid?
will i lose data on my droid by removing the battery?
