Extended Batteries vs. Regular Batteries
This is a discussion on Extended Batteries vs. Regular Batteries within the Droid X Help forums, part of the Droid X Discussion category; Are extended batteries better than the regular ones? Is the extra cost worth it?Sundaz...
Results 1 to 2 of 2
Thread: Extended Batteries vs. Regular Batteries
    Points: 509, Level: 10
    Level completed: 18%, Points required for next Level: 41
    Overall activity: 0.7%
    sundaz2012's Avatar
    56801
    Mar 2012
    9
    Points: 17,911, Level: 85
    Level completed: 13%, Points required for next Level: 439
    Overall activity: 99.8%
    6,225
    138 times
    While everyone's experience with battery life will differ simply because everyone uses their phone in a different way I'd say that over all the extended battery is worth it. However keep in mind that sometimes the original back to your phone will not work with the extended battery. If it's too tight it can even cause problems with your screen so you not only have to buy the battery but it is recommended that you buy the new back too. Now if you have a new back you may have issues with a case fitting it normally like it would with the original back. Just something to think about.
  1. Extended batteries??? Which ones to get?
    By ac99 in forum Droid X General Discussion
    Last Post: 09-07-2011, 09:05 PM
  2. Extended Batteries 2400mAh and 3000mAh
    By luppas in forum Droid X Accessories
    Last Post: 04-26-2011, 01:07 AM
  3. Extended batteries and cases
    By TheJustPull in forum Droid X General Discussion
    Last Post: 04-16-2011, 09:04 AM
  4. Battery Left and extended batteries
    By RuggerJoe in forum Droid X Apps
    Last Post: 02-10-2011, 09:58 PM
  5. Extended Batteries and Cover
    By wilyums in forum Droid X Accessories
    Last Post: 01-20-2011, 11:11 PM
best droid x2 extended battery
droid x 3000 battery
droid x extended battery vs normal
droid x extended battery vs standard battery
extended battery / vs regular battery for droid x
extended battery vs standard on droid x
extended vs normal battery
phone new battery vs extended ? forum
x2 extended battery forum
