battery not holding charge
This is a discussion on battery not holding charge within the Droid X Help forums, part of the Droid X Discussion category; How long is the battery life for DROID X? Mine is two years old and not holding a charge for more than an hour when ...
Results 1 to 10 of 12
Thread: battery not holding charge
    Points: 509, Level: 10
    Level completed: 18%, Points required for next Level: 41
    Overall activity: 0.7%
    sundaz2012's Avatar
    56801
    Mar 2012
    9
    How long is the battery life for DROID X? Mine is two years old and not holding a charge for more than an hour when I surf the net.Sundaz
    Points: 970, Level: 16
    Level completed: 70%, Points required for next Level: 30
    Overall activity: 1.6%
    mhans311's Avatar
    52442
    Dec 2011
    145
    After 2 years its probably about time to get a new battery.
    Bionic'd from my tapatalk.
    Points: 26,429, Level: 97
    Level completed: 8%, Points required for next Level: 921
    Overall activity: 47.2%
    7,093
    338 times
    Yeah if you got two solid years out of it I'd say that's pretty good. You should be able to get a new battery for pretty cheap now a days.
    Natey2's Avatar
    19853
    112
    8 times
    My DROIDX battery is over 2 years old, and battery lasts for about a day. Really depends on what you have running. K9 mail is a major user of battery on my phone.
    I also use Juice Defender Beta.
    Sent from my unrooted DroidX using Tapatalk
    Natey2's Avatar
    19853
    112
    8 times
    I noticed a spot in the middle of my screen that looked wet. My original Motorola BH5X battery (mfg: 7/2010) has started bulging slightly in the middle, and is putting slight pressure on the screen. I have a silicone case, so I can leave the battery door not fully shut to reduce this pressure.
    Time to get a new battery...
    Points: 26,638, Level: 97
    Level completed: 29%, Points required for next Level: 712
    Overall activity: 62.2%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    Quote Originally Posted by Natey2 View Post
    Mine was less then a year old when they happened
    Cellar Door
    "Who are you people and where is my horse?"
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 3,833, Level: 39
    Level completed: 22%, Points required for next Level: 117
    Overall activity: 0.8%
    250 Experience Points31 days registered100 Experience PointsCreated Album pictures7 days registered
    TruePCs's Avatar
    23665
    Rhode Island
    163
    My OEM battery lasted about 1 year too, I purchased a new OEM one on ebay for just a few bucks shipped, I had bad luck with the off brand batteries from ebay sellers, they just do not last but are cheap and better than nothing when on the road with no charger. It has been about another year by now and this battery is still ok.
    OTA GB.
    Natey2's Avatar
    19853
    112
    8 times
    Which makes me wonder... what about all those new Motorola (and other) phones with non-removable batteries? What happens after 2 years?
    Points: 8,909, Level: 63
    Overall activity: 43.1%
    1,340
    79 times
    Bad stuff lol. That is why I refuse to buy a phone without a removable battery. Luckily when my upgrade was up the best phone of the moment (GS3) has a removable battery.
    For a bit more info battery tech has improved some as far as longevity of battery (not how long a specific mAh of battery will last but lifespan) so you can expect them to last slightly longer than the DX battery. Most phones without a removable battery can also be cracked open with a bit of work and the battery replaced, although it may take a bit of soldering or otherwise (depends on the specific device) but its most definitely not as easy as the pop-off back door it could be.
    Natey2's Avatar
    19853
    112
    8 times
    A merchant on Amazon sent me a BH6X SNN5893A instead of a BH6X SNN5880 battery. I'll have to return it and keep looking for a SNN5880 or get a BH5X.
  1. How to Calibrate Battery And Charge Battery To Max mV
    By cobracon71 in forum Gingerbread Development and Hacking
    Last Post: 06-21-2012, 09:03 PM
  2. Battery charge led
    By dr.banks in forum Liquid
    Last Post: 03-29-2012, 12:44 AM
  3. New battery won't charge
    By Pugsley in forum Droid X Help
    Last Post: 03-14-2012, 04:33 PM
  4. First Charge of a new battery?
    By cantstopthesignal in forum Droid X General Discussion
    Last Post: 02-23-2011, 06:50 AM
  5. No USB charge, hot battery?
    By mreyeball in forum Droid X General Discussion
    Last Post: 09-08-2010, 02:54 PM
Droid x wont hold charge
bh5x battery won't charge
droid battery not holding charge
droid not holding charge
droid x not holding charge
droid x2 battery not holding charge
droid x2 battery wont stay charged
droid x2 not holding charge
droid x2 will not hold charge
motorola droid not holding charge
