bought droidx for wife from friend. it was rooted and workin fine. but she wanted to install an update from a saved file on the sd card because the phone said it only had partial root.now stuck on liberty screen.
This is a discussion on droidx stuck on liberty screen within the Droid X Help forums, part of the Droid X Discussion category; bought droidx for wife from friend. it was rooted and workin fine. but she wanted to install an update from a saved file on the ...
Do you know what system version it was on? Most likely .602, .605, or .621.
Sent from my Black Iced X
