DX not booting into Clockwork Recovery
This is a discussion on DX not booting into Clockwork Recovery within the Droid X Help forums, part of the Droid X Discussion category; Have you been using the blackberry cord the entire time? I know it sounds strange but the cord can be a big deal when trying ...
Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 53
Thread: DX not booting into Clockwork Recovery
  1. #41
    Points: 17,922, Level: 85
    Level completed: 15%, Points required for next Level: 428
    Overall activity: 99.8%
    6,228
    138 times
    Have you been using the blackberry cord the entire time? I know it sounds strange but the cord can be a big deal when trying to SBF. Do you still have the one for the DX?
  3. #42
    Points: 8,551, Level: 62
    Level completed: 34%, Points required for next Level: 199
    Overall activity: 99.6%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    3,017
    120 times
    What ^he^ said!! It does matter
    teleported from my wizardry DX
  4. #43
    Yes I've been using the Blackberry USB from the beginning, I figured that since it showed in Device Manager that it was capable of flashing the device. I still have the OEM cable somewhere though.
  5. #44
    51337
    Nov 2011
    Smith river CA
    3,017
    120 times
    Seeing your phone and communication with it using a different USB cable is fine but writing to it for an sbf is more technical and needs the Motorola cable for a success.
  6. #45
    Ok I will try it with the OEM and let you know how it goes, thanks for your help, I really appreciate it.
  7. #46
    51337
    Nov 2011
    Smith river CA
    3,017
    120 times
    No problem and good luck, let us know the outcome.
  8. #47
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    Yup. I can use my wife's Fascinate cable to read/write files to my X, but only my X cable will work for a SBF.
    Sent from my Black Iced X
  9. #48
    Tried 3 different cables, don't know if they were OEM or not, one was a very heavy thick cable. Nothing major has changed, still goes into bootloader and I can still bring up the M Logo but now the green LED appears when the Droid is attached to the computer, it didn't do that before. I don't know if this means it's charging, I also feel heat on the rear lower section, i don't know if this is normal or if this is a malfunction of another component. I wanr to flash it with Linux but can't find the same SBF in ISO format.. 1FF-p3a_shadow_cdma_shadow-user-2.3.4-4.5.1_57_DX8-51-120111-test-keys-signed-Verizon-US.sbf...this one gives me no "Service Req'd" after flashing. Might not work, but it's a last ditch effort.
  10. #49
    6,228
    138 times
    There is no .621 iso file that I'm aware of, sorry. Can always try the .604 one again. Linux solution to your Windows/RSD lite problems
  11. #50
    Ok fellas, tried every SBF file available, tried 3 different USB cables, tried the Linux options and the RSD Lite, still at bootloader so I'm guessing this thing is bricked. Wish it would read the SD Card but I can see that isn't an option. Thanks for all your help, You would have thought that they would have made a phone that a slight amount of moisture wouldn't kill but that's just daydreaming. I appreciate your assistance guys.
  1. Help! Phone booting into Clockwork mod after power up
    By kalyanamitras in forum Droid X Rooted Issues
    Last Post: 09-09-2011, 05:16 AM
  2. booting into the wrong clockwork
    By Nemo aeternamn in forum Droid X Hacks
    Last Post: 08-25-2011, 10:12 AM
  3. DX keeps booting into Clockwork mod recovery....
    By wiskytango in forum Droid X Help
    Last Post: 02-11-2011, 05:47 AM
  4. Unintentionally Booting into Clockwork Recovery
    By bigb1114 in forum Droid X Help
    Last Post: 02-02-2011, 04:44 PM
  5. Plugged in and booting into clockwork
    By redwinger2001 in forum Hacking Help
    Last Post: 01-18-2011, 01:23 PM
booting into recovery droid x
droid 2 not booting into clockwork
droid x clockwork recovery
droid x recovery clockwork shadow without root
dx clockwork wont work
failed flashing process: failed flashing process interface ap-os: error getting droid x
how to boot into clockwork recovery droid x
how to use bootstrap recovery droid x
kang droid x
who to boot droidx inti recovery .621
