hello...i did nothing for my phone to go to safe mode..i have tried i think almost everything can someone tell me how to disable it...thanks
This is a discussion on stuck in safe mode within the Droid X Help forums, part of the Droid X Discussion category; hello...i did nothing for my phone to go to safe mode..i have tried i think almost everything can someone tell me how to disable it...thanks...
Try this
Usually a force Safe Mode boot usually lean towards a bad app or hardware hickup, try removing the sd card and see if you can boot clean. Another option is to try booting into recovery mode and clear the cache. Have you tried to just simply pull the battery?Read here How To Get To Stock Recovery to see how to get into stock recovery. You are most likey on gingerbread.
