Unlocking droid X for virgin mobile
This is a discussion on Unlocking droid X for virgin mobile within the Droid X Help forums, part of the Droid X Discussion category; Hey all. I have a rooted droid x with a bad ESN. I would like to use virgin mobile on it. Is this possible even ...
Thread: Unlocking droid X for virgin mobile
    Hey all. I have a rooted droid x with a bad ESN. I would like to use virgin mobile on it. Is this possible even tho I have a bad ESN? Thanks.
    Sent from my Milestone X using Droid X Forums
    Oops wrong forum. Can an admin move this to the Droid X forums?
    Points: 26,429, Level: 97
    Level completed: 8%, Points required for next Level: 921
    Overall activity: 47.2%
    7,093
    338 times
    Questionable content... Why does your phone have a bad ESN?
    Points: 8,909, Level: 63
    Overall activity: 43.1%
    1,340
    79 times
    Moved per request of OP.
    In regards to flashing if it has a bad ESN it will most likely not be approved due to being a CDMA phone. Bad ESN is questionable, but if it is just a legitimate mistake (like you bought a phone used and the previous owner forgot to deactivate it prior to selling it) that is fine. But usually if it has a bad ESN they won't allow it on their network. GSM phones can often still be done because they rely on the SIM card, the DX does not. Each different carrier has the right to approve or disprove phones on their network. If it has a bad ESN it will be likely that Virgin Mobile will not allow it on their network.
    Also keep in mind Virgin Mobile runs on Sprint's network and generally Sprint does not allow Verizon phones on their network. Also, I believe even when flashed across there can be radio issues regarding data, although I have never attempted it. Like I said, due to the bad ESN it will most likely not be approved anyways.
    Points: 895, Level: 15
    Level completed: 95%, Points required for next Level: 5
    Minni's Avatar
    38986
    unlocking Droid x?
    this has probably been asked several times before but i have a droidx thru verizon that is not active but would like to unlock it so i could use a different carrier or buy a card for mins. is there a way to do this?
  1. unlocking Droid x?
    By Brooke_654 in forum Droid X Hacks
    Last Post: 08-05-2012, 12:16 PM
  2. Droid x verizon to virgin mobile?
    By MIck11 in forum Hacking Help
    Last Post: 12-13-2011, 12:37 AM
  3. Droid X Virgin
    By defensity in forum New Member Introductions & Site Assistance
    Last Post: 06-03-2011, 06:43 PM
  4. Droid X unlocking?
    By droidiam in forum Droid X General Discussion
    Last Post: 04-07-2011, 01:31 PM
  5. unlocking a droid x
    By nps1221 in forum Droid X Help
    Last Post: 12-05-2010, 02:35 PM
droid x for virgin mobile
droid x on virgin mobile
droid x virgin mobile
droid x2 on virgin mobile
droid x2 virgin mobile
flash droid x to virgin mobile
flash droid x2 to virgin mobile
how to flash droid x to virgin mobile
unlock droid x for virgin mobile
virgin mobile droid x
