Cannot get Droid X to connect in CDMA 2.7
I have loaded the drivers for my Droid X and when I create USB Serial port in HV Virtual Serial port it says Connected for about 10 seconds and then says closed. In CDMA 2.7 it says Phone failed to
answer.
I have tried different drivers but cannot get anything to work.
Settings used in HW virtual serial port
1.NVT enabled is unchecked
2. IP address: 192.168.16.2
3. port; 11008
comport used was 19
Phone is in PC mode
Droid X
System Ver. : 4.5.604, MB809.ACG-nTELOS.en.US
Model #: Milestone X
Android Ver. 2.3.5
kernal Ver 2.6.32.9-geadffa3
mcbk83@il93Inxdroid08 #1
build # 4.5.1_57_mx2-34
ERI version Unknown
PRL Version Unknown
08-17-2012 10:10 PM
