droid x charge with wall charger but NOT usb plug into pc
This is a discussion on droid x charge with wall charger but NOT usb plug into pc within the Droid X Help forums, part of the Droid X Discussion category; i recently got a used droid x. when plug into the wall charger it will charge but my pc and laptop will not recognize it ...
Thread: droid x charge with wall charger but NOT usb plug into pc
    Points: 176, Level: 3
    Level completed: 52%, Points required for next Level: 24
    Overall activity: 1.3%
    cfli1688c1's Avatar
    59029
    Jun 2012
    6
    but my pc and laptop will not recognize it and thus will not charge it
    try put the battery and reboot, did not help
    anyone know whats wrong?
    Points: 17,978, Level: 85
    Level completed: 26%, Points required for next Level: 372
    Overall activity: 99.8%
    6,245
    138 times
    Did you try setting your phone to pc/charge only mode?
    Edit: came back to ask about the drivers too but Anarchy beat me to it.
    Points: 178, Level: 3
    Level completed: 56%, Points required for next Level: 22
    Overall activity: 8.7%
    SonOfAnarchy0210's Avatar
    61005
    Aug 2012
    55
    Did you download the drivers for your phone?
    cfli1688c1's Avatar
    59029
    Jun 2012
    6
    i try it with my wife's droid x, it will should the charging battery, mine does not, same laptop, same cable
    again, i can plug in the wall and it will charge...
    6,245
    138 times
    Are you using the cable that came with your phone? Sometimes "off-brand" cables can be the issue. Also try pulling your battery while phone is on and then replacing it. My last suggestion would be to uninstall and reinstall the drivers.
  1. Replies: 8
    Last Post: 12-29-2011, 10:32 PM
  2. Droid X not charging on wall charger on liberty 3
    By WyldStyl3 in forum Team Liberty
    Last Post: 12-16-2011, 07:26 PM
  3. Will only charge from usb? Wont recognize wall charger
    By duro78 in forum Droid X Rescue Squad
    Last Post: 08-18-2011, 12:16 PM
  4. droid x wont charge with wall charger
    By Barker412 in forum Droid X General Discussion
    Last Post: 01-19-2011, 12:27 AM
  5. Droid X wall charger USB cable
    By DroidXXX in forum Droid X Accessories
    Last Post: 07-18-2010, 06:32 PM
android phone not charging with wall charger but just using the usb port
android phone will not charge with a wall charger but will through a usb port
computer will charge but not register android
driod x not charging through laptop usb
droid x does not recognize usb connection
droid x will charge to wall charger but will not
how to charge a droid x
how to charge my droid x with computer
my droid x is not charging from wall only from computer what do i do
setting a driod x to charge from pc
