crap phone wont connect to wifi
This is a discussion on crap phone wont connect to wifi within the Droid X Help forums, part of the Droid X Discussion category; well this is only one of the problems i have with my droid. when i connect to the wifi in my house, i get full ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: crap phone wont connect to wifi
    well this is only one of the problems i have with my droid. when i connect to the wifi in my house, i get full bars, and its blue, but then if i go to use an app that requires wifi, or use the browser, nothing will load and the wifi bars turn gray. i dont understand why, because im using the wifi on my laptop right now, and all my friends use it on their phones. so why cant i use it on my phone? did a factory data reset last night and all that did was waste time
    Points: 9,511, Level: 65
    Level completed: 54%, Points required for next Level: 139
    Overall activity: 99.7%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    3,209
    128 times
    Did you try to forget wifi settings and reconnect? Did it work before then suddenly stop working?
    teleported from my wizardry DX
    Quote Originally Posted by clothednblack View Post
    yes, and it worked fine when i first got the phone. after like a month and a half it just stopped working
    Points: 7,325, Level: 56
    Level completed: 88%, Points required for next Level: 25
    Overall activity: 24.2%
    1,341
    78 times
    Rooted/ROMd or stock?
    Sent from my jellybeaned AOKP GSIII
    stock. i tried rooting it but it didnt work
    Advocate X
    Points: 16,817, Level: 82
    Level completed: 94%, Points required for next Level: 33
    Overall activity: 5.6%
    The persuader's Avatar
    12986
    Maine
    5,603
    66 times
    Quote Originally Posted by ihatemydroid View Post
    How Old is your Rooted? 4/5 years old...
    Its Bubba
    "Stubborn In Your Bones "
    "Stubborn In You're Bones"
    Points: 42,321, Level: 100
    Overall activity: 99.9%
    Activity Award
    DirtyDroid's Avatar
    28665
    Upstate,NY
    13,861
    165 times
    Quote Originally Posted by The persuader View Post
    Its Bubba
    Bubba, how ya been ?
    tap'd from the N•Seven
    1,341
    78 times
    I would say if you want to stay on stock its about time to do an SBF, otherwise rooting may be able to fix it and giving you a more awesome OS/ROM
    Advocate X
    12986
    Maine
    5,603
    66 times
    Good morning I-Hat
    Have you Updated your Router...how Old is your Router?
    Its Bubba
    "Stubborn In Your Bones"
    Points: 1,127, Level: 18
    Level completed: 27%, Points required for next Level: 73
    Overall activity: 4.8%
    Toad's Avatar
    54722
    Jan 2012
    Idaho Falls, Idaho
    26
    First of all, I absolutely love my Droid X.
    That being said, mine has recently stumped me with wifi troubles when I'm at home.
    I have:
    1) SBFd .621 using RSD Lite and then rooted using the Magic method (no dice),
    2) Flashed Goose's Wifi Fix (still no dice),
    3) Changed the battery settings, (no luck)
    4) forgot and re-signed into the network (multiple times throughout the process), still no luck,
    3) Flashed Dubbsy's Liquid ICS with GoogleNow and RAZR Launcher (which by the way is awesome), no dice,
    4) Installed Nandroids that have worked in the past (no dice),
    5) Flashed OA VXLR multiple times with each (then both) of the Wifi fixes (nothing),...
    P.S.: Each time I flashed a ROM I did a mini SBF (Wipe Data/Factory Reset, Wipe Cache, Wipe Dalvik Cache, Format System).
    I am on the 2.6.32.9-g1282440 mcbk83@il93lnxdroid08 #1 Wed Jan 11 12:19:23 CST 2012 Kernal
    I have never had a Wifi problem like this in the two+ years I have owned the X.
    It works at work, at Target, McD's... But not at home. I haven't changed anything at home; and all of my other stuff (laptop, Wii, Kids phones and iPods...) have continued working.
    I have tried:
    1) Disabling router security,
    2) Changed from b to n, to g, to all,
    3) Changed from TKIP to AES to both...
    ...and my router firmware is up to date.
    Not sure what to do and would be grateful for some guidance.
    Thanks,
    Toad
  1. Replies: 2
    Last Post: 09-10-2011, 08:18 PM
  2. My PS3 can't connect to wifi if my phone is using it
    By Snipples007 in forum Droid X General Discussion
    Last Post: 05-06-2011, 03:31 AM
  3. wont wifi connect
    By thewakka1 in forum Droid X Rescue Squad
    Last Post: 11-22-2010, 08:04 PM
  4. holy crap thats a big phone!!
    By goliath602 in forum Droid X General Discussion
    Last Post: 11-21-2010, 06:51 PM
  5. Phone wont connect to the PC anymore.
    By biggestmexi in forum Droid X Help
    Last Post: 07-19-2010, 09:21 AM
aokp wifi settings stopped driod x
droid x wont connect to wifi
gray wifi bars with loop
my droid x doesnt connect to wifi
phone wont stay connected to home wifi
why does my wifi on droid turn gray
why is my wifi turn gray on my phone?
why wont my android phone stay connected to wifi
why wont my droid x connect to wifi
y does my phones wifi on a droid turn gray
