I have a Droid X that I've had a for a while but not used for quite some time now. The reason I stopped using it was because it was stuck in a boot loop and I couldn't fix it. Here's what I tried.
I held the Home button down and powered up. I selected "wipe cache partition" and then "wipe data/factory reset", and then "reboot system now". The boot loop continues. Is there anything else I can try? I tried removing the SD card and then tried the reset but got the same results. I would really love to get this phone working so I can give it to my father to use, but right now it's useless.
Is there a way to boot into Safe Mode? Is there a way to "apply update from sdcard"? If so, what update can I apply? I'd just like to get the stock on there, but I'm willing to put anything on there just go get it working again.
Thanks so much for any help!!!
