GPS Issue
This is a discussion on GPS Issue within the Droid X Help forums, part of the Droid X Discussion category; My old Droid X phone broke so my brother in law gave me another Droid X until our upgrade. I geocache and use the live-geocache ...
Thread: GPS Issue
    Points: 96, Level: 1
    Level completed: 92%, Points required for next Level: 4
    Overall activity: 1.2%
    kayakdannj's Avatar
    60849
    Aug 2012
    8
    GPS Issue
    My old Droid X phone broke so my brother in law gave me another Droid X until our upgrade. I geocache and use the live-geocache app. My old DroidX worked great on the map feature and the GPS was very accurate. This DroidX I have now is off by miles. I think it is using cell towers to pinpoint me. How can I get the GPS to work like the old phone? I ran GPS Test app and I am getting 8-9 satilites.
    Points: 3,147, Level: 34
    Level completed: 65%, Points required for next Level: 53
    Overall activity: 2.7%
    newmanx4's Avatar
    34469
    703
    27 times
    Try this.
    http://www.droidforums.net/forum/sho....php?p=2103135
    Two posts down from there explains why it works. (If it solves your problem)
    Sent from my Black Iced X
    Themer
    Points: 10,971, Level: 69
    Level completed: 31%, Points required for next Level: 279
    Overall activity: 18.1%
    jeems's Avatar
    40702
    3,747
    73 times
    Check out my themes:
    kayakdannj's Avatar
    60849
    Aug 2012
    8
    Don't know what rooted means so I doubt it. Tried the tape and two apps from the other thread and didn't work. Although we have some bad storms in the area right now so I will try again later.
    Themer
    jeems's Avatar
    40702
    3,747
    73 times
    GPS might just be going bad, but if you are getting 8-9 satellites I can't imagine that's the issue. I would try another app that uses GPS to see if they work (mytracks, google maps, mapquest, strava all access the GPS and are free). If those work then it might be an issue with the app you are using. Maybe try uninstalling and reinstalling it.
  1. Replies: 15
    Last Post: 06-29-2012, 10:23 PM
  2. .apk issue
    By kevinarjun in forum Off-Topic Discussion
    Last Post: 02-11-2012, 06:01 AM
  3. I have an issue
    By shax0r in forum Droid X General Discussion
    Last Post: 08-13-2011, 05:09 PM
  4. Wireless Network Connection issue after preroot GB issue
    By AngelInRed in forum Droid X2 Support
    Last Post: 08-08-2011, 03:10 PM
  5. Camera issue/picture issue
    By ViciousJelqs in forum Droid X Help
    Last Post: 12-05-2010, 12:15 AM
droid x map not accurate
droid x2 gps issues
droid x2 strava issues
strava problems on droid x
