Help! The other day i flashed cm7 onto my friends droid x. It was working fine for a few days then out of nowhere everything started to force close and it wouldn't even attempt to boot. So I got it into the bootloader and figured i would just sbf it like I have many times before. I used all the same tools and sbf file that I have used before, except this time it failed. Everytime I attempted it, it would fail. This was using .602. So i figured I would try to sbf to .621 to see if that would work. Nothing. Bootloader said OK to program. So I downloaded .605 and attempted to sbf that, didnt work bootloader now says MEM_MAP Blank Service Req'd. I tried using the linux methods and nothing will work. When I try to boot it, it just stays at the red M. Also, when every i put the battery in it, the back and search buttons light up, but nothing else. This is before i attempt to boot it or access the bootloader. Any Help?
