Droid X Stuck on Motorola screen
This is a discussion on Droid X Stuck on Motorola screen within the Droid X Help forums, part of the Droid X Discussion category; Okay so im trying to fix my moms phone.Heres the inf of what i tried. I tried holding power and home for factory reset. No ...
Thread: Droid X Stuck on Motorola screen
    Okay so im trying to fix my moms phone.Heres the inf of what i tried. I tried holding power and home for factory reset. No deal stayed on M screen, tried about 10 times holding for 1+minute each time. she said it stopped working after powering down and switching batteries(has two). Can get to bootloader, its 30.04 says k to program, nothing works. cant go to verizon because this phone has passed its warranty.
    tl:dr; Phone WONT make it to factory reset, stuck on Motorala load, 30.04.
    any help is appreciated.
    P.S no edits, ("stock"?)
    Points: 8,798, Level: 63
    Level completed: 16%, Points required for next Level: 252
    Overall activity: 99.6%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    3,058
    125 times
    Step 1. Make sure your device is fully powered down/off Step 2. Press and hold the Volume Down, as well as the Home Button on your device Step 3. While keeping those 2 buttons pressed down, also press on the Power button Step 4. Once you see your screen flicker/flash (note: You might have to press a key on your device to see that you are actually booted into the Stock Recovery). Step 5. Once completed you should see a triangle, hit both volume buttons and then select factory reset
    teleported from my wizardry DX
    that brings me to bootloader where im stuck again :/
    RS Team Leader
    Points: 21,500, Level: 92
    Level completed: 15%, Points required for next Level: 850
    Overall activity: 20.5%
    popcenator's Avatar
    21238
    Omaha, NE
    8,208
    132 times
    Have you tried an SBF? If that doesn't work and keeps booting to the bootloader, something hardware wise might be the culprit.
  1. Replies: 10
    Last Post: 09-05-2011, 04:36 PM
  2. Droid X Stuck at Motorola Loading Screen
    By Acewolf in forum Droid X Help
    Last Post: 04-27-2011, 12:03 PM
  3. Droid X is stuck on "Motorola" boot screen
    By danarosetti in forum Droid X Help
    Last Post: 02-19-2011, 09:30 AM
  4. Stuck on Motorola screen...
    By xDROID in forum Droid X General Discussion
    Last Post: 09-19-2010, 05:47 PM
  5. Stuck on Motorola screen...
    By xDROID in forum Droid X Help
    Last Post: 09-08-2010, 11:12 PM
driod 4 stuck on driod screen
droid phone stuck on motorola screen
droid x stuck on M screen
droid x stuck on motorola screen
how to reset motorola droid x
motorola droid stuck on emergency screen
motorola phone stuck on droid scrreen how do i fix it
motorola stuck on droid screen
my droid ia stuck on the motorola sreen logo
my droid x is stuck on the motorola screen
